Defining Business Services
The topics in this section describe how to maintain business services.
Note that several context sensitive dashboard zones appear on this page and are visible on all tabs.
  • Schema Tips. This zone provides several links to launch help topics related to valid schema syntax.
  • Generate Schema. This zone includes a button that can be used to generate the schema based on the XML of its related Service. Once generated, adjust the schema as desired.
