Defining Organizations
You use the Organization portal to display and maintain organizations.
You can access the portal by selecting Admin, then Location, then Organization. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Organization: This zone provides information about the organization.
  • Child Locations / Organizations: This zone lists any child locations and/or organizations for the current organization.
