Upgrade Install
This section describes how to upgrade the database components of Oracle Utilities Market Settlements Management, including:
Supported Upgrade Path
Upgrade to Oracle Utilities Market Settlements Management V2.5.0.2.0 is supported from Oracle Utilities Market Settlements Management V2.5.0.1.1.
This section assumes that an existing Oracle Utilities Market Settlements Management is installed on top of Oracle Utilities Application Framework, same as a Oracle Utilities Market Settlements Management V2.5.0.1.1 installation on top of a Oracle Utilities Application Framework V4.5.0.1.1 installation.
Copying and Decompressing Install Media
Note that the Oracle Utilities Meter Data Management database component is a cumulative package comprising of data used by Oracle Utilities Market Settlements Management.
To copy and decompress the Oracle Utilities Application Framework and Oracle Utilities Meter Data Management database:
1. Download the Oracle Utilities Application Framework V4.5.0.2.0 Multiplatform and Oracle Utilities Meter Data Management V2.5.0.2.0 Multiplatform from the Oracle Software Delivery Cloud.
2. Create a temporary directory, such as C:\OUMDM\temp or /OUMDM/temp (referred to below as <TEMPDIR>. This directory must be located outside any current working Oracle Utilities application environment. All the files that are placed in this directory as a part of the installation can be deleted after a successful installation.
3. Copy the FW_V4.5.0.2.0.zip and MDM_V2.5.0.2.0.zip files from the downloaded package to <TEMPDIR>/DB directory.
4. Unzip the FW_V4.5.0.2.0.zip and MDM_V2.5.0.2.0.zip files to a temporary folder. These files contains the database components required to install Oracle Utilities Application Framework and Oracle Utilities Meter Data Management databases.
Installing the CISADM Schema
Important: Make sure to take a backup of your database before carrying out the upgrade process.
You must install Oracle Utilities Application Framework V4.5.0.2.0 prior to Oracle Utilities Market Settlements Management. The files for Oracle Utilities Application Framework installation are located in the FW_V4.5.0.2.0 folder. Install Oracle Utilities Application Framework V4.5.0.2.0.
This section includes the following:
Installing the Oracle Utilities Application Framework Database Component using OraDBI.jar
Prepare the following parameters before installation:
• The name of the database server in which the database is configured - DB_SERVER
• The listener port number of the database - PORT
• The target database name in which the product is to be installed - SERVICE_NAME
• A database user that will own the application schema (for example: CISADM) - DBUSER
• Password of the database user that will own the application schema - DBPASS
• A database user that has read-write (select/update/insert/delete) privileges to the objects in the application schema (for example, CISUSER). The application will access the database as this user - RWUSER
• A database user with read-only privileges to the objects in the application schema. (for example: CISREAD) - RUSER
• A database role that has read-write (select/update/insert/delete) privileges to the objects in the application schema. (for example: CIS_USER) - RW_USER_ROLE
• A database role with read-only privileges to the objects in the application schema. (for example: CIS_READ) - R_USER_ROLE
• Location for jar files. (The Jar files are bundled with the database package) - CLASSPATH
• Java Home (for example: <Java Install location>) - JAVA_HOME
• Database user password with read-write privileges - RWUSER_PASS
• Database user password with read-only privileges - RUSER_PASS
You can execute OraDBI.jar using either of the following methods:
Granting Privileges to Database Roles
Make sure to provide the CREATE SYNONYM grants to database role with read-write privileges and read-only privileges.
GRANT CREATE SYNONYM TO CIS_USER;
GRANT CREATE SYNONYM TO CIS_READ;
Using the Interactive Mode
The following procedure lists the steps to install the schema for Oracle Utilities Application Framework V4.5.0.2.0 using OraDBI.
Run the following command with the defined parameters on the command prompt from the ..\DB/FW_V4.5.0.2.0/Install-Upgrade/ directory.
1. Open a command line prompt.
2. Set Java Home.
export JAVA_HOME=<Java Install location>/jdk
3. Set the class path.
export CLASSPATH=<TEMPDIR>/jarfiles/*
4. Run the following command:
$JAVA_HOME/bin/java -Xmx1500M -cp $CLASSPATH com.oracle.ouaf.oem.install.OraDBI -p <RWUSER_PASS>,<RUSER_PASS>
The utility prompts you to enter values for the following parameters as per your environment:
• Name of the database server: <DB SERVER>
• Port no: <PORT>
• Name of the target database: <SERVICE_NAME>
• Name of the owner of the database schema: <DBUSER>
• Password of the user name: <DBPASS>
• Location of Java Home: (for example: <Java Install location>): <Java Home>
• Oracle user with read-write privileges to the database schema: <CISUSER>
• Oracle user with read-only privileges to the database schema: <CISREAD>
• Oracle database role with read-write privileges to the database schema: <CIS_USER>
• Oracle database role with read-only privileges to the database schema: <CIS_READ>
• Enter the name of the target schema where you want to install or upgrade: <CISADM>
• Enter the password for the target schema: <CISADM password>
This process generates log files in the directory Install-Upgrade/logs. Make sure to check log files for any errors.
Note: For OraDBI jar, you may receive the following message in the display output or logs. These errors can be safely ignored and the process should proceed to completion.
- 2016-05-23 16:31:38,315 [main] ERROR (common.cryptography.KeyStoreWrapperFactory) The keystore file '<filename>' does not exist.…
This file is either provided by the property com.oracle.ouaf.system.keystore.file or expected to exist at the default file location null Attempting to use the legacy cryptography.
- 2016-05-23 16:31:38,566 [main] INFO (oem.install.OraDBI)
Using the Command Line Mode
Run the following command with the defined parameters on the command prompt from ../DB/FW_V4.5.0.2.0/Install-Upgrade directory.
java com.oracle.ouaf.oem.install.OraDBI -d jdbc:oracle:thin:@<DB_Server>:1521/
<SERVICE_NAME>,<DBUSER>,<DBPASS>,<RWUSER>,<RUSER>,<RW_USER_ROLE>,< R_USER_ROLE>,<DBUSER> -l 1,2 - q true -p <RWUSER_PASS>,<RUSER_PASS>
Drop Column from Database
Connect to CISADM schema through SQL and the drop the following column.
ALTER TABLE CI_XAI_RCVR_CTX DROP COLUMN CTXT_VAL;
If you are running Oracle GoldenGate, you may need to drop the log group. Use following script to drop the column.
select LOG_GROUP_NAME from user_log_groups where table_name='CI_XAI_RCVR_CTX'
ALTER TABLE CI_XAI_RCVR_CTX DROP supplemental log group GGS_CI_XAI_RCVR_CTX_111254
Installing the Oracle Utilities Market Settlements Management Database
Note that the Oracle Utilities Meter Data Management database component is a cumulative package comprising the data used by Oracle Utilities Market Settlements Management.
• The name of the database server in which the database is configured: DB_SERVER
• The listener port number of the database: PORT
• The target database name in which the product is to be installed: SERVICE_NAME
• A database user that will own the application schema (for example: CISADM): DBUSER
• Password of the database user that will own the application schema: DBPASS
• A database user that has read-write (select/update/insert/delete) privileges to the objects in the application schema (for example: CISUSER). The application will access the database as this user: RWUSER
• A database user with read-only privileges to the objects in the application schema (for example: CISREAD): RUSER
• A database role that has read-write (select/update/insert/delete) privileges to the objects in the application schema (for example: CIS_USER): RW_USER_ROLE
• A database role with read-only privileges to the objects in the application schema (for example: CIS_READ): R_USER_ROLE
• Location for jar files (jar files are bundled with the database package): CLASSPATH
• Java Home (for example: <Java Install location>): JAVA_HOME
• Database user password with read-write privileges: RWUSER_PASS
• Database user password with read-only privileges: RUSER_PASS
The following procedure lists the steps to install the schema for Oracle Utilities Market Settlements Management using OraDBI.
Run the following command with the defined parameters on the command prompt from the ../DB/MDM_V2.5.0.2.0/Install-Upgrade/ directory.
2. Set Java Home.
• Port no: <PORT>
• Oracle user with read-write privileges to the Database Schema: <CISUSER>
• Oracle user with read-only privileges to the Database Schema: <CISREAD>
• Oracle database role with read-write privileges to the Database Schema: <CIS_USER>
• Oracle database role with read-only privileges to the Database Schema: <CIS_READ>
Run the following command with the defined parameters on the command prompt from ../DB/MDM_V2.5.0.2.0/Install-Upgrade/ directory.
If you chose to continue, OraDBI first checks for the existence of each of the users specified and prompts for their password, default tablespace, and temporary tablespace.
Optional: This optional step should be executed if you have installed Oracle Utilities Meter Data Analytics 2.5.0.0.2 (2.5 Patch Set 2), or if you plan to install it in the future.
• Navigate to ../DB/MDM_V2.5.0.2.0/Post-Upgrade folder and run Materialized_View_Creation.sql from sql prompt.
• Connect to Database Owner Schema.
For example: <CISADM>/<CISADM>@<SERVICE_NAME>
• Run Materialized_View_Creation.sql as @Materialized_View_Creation.sql from sql prompt.
After the required changes are complete, configure security by following the steps in the Configuring Security section.
To configure security:
1. Set PATH.
export PATH=$JAVA_HOME/bin:$PATH
2. Set CLASSPATH.
export CLASSPATH=<TEMPDIR>/DB/FW_V4.5.0.2.0/jarfiles/*
3. Run the following command with the defined parameters on the command prompt.
java com.oracle.ouaf.oem.install.OraGenSec -d <DBUSER>,<DBPASS>,jdbc:oracle:thin:@<DB_Server>:1521/<SERVICE_NAME> -a A -r <RW_USER_ROLE>,<R_USER_ROLE> -u <RWUSER>,<RUSER> -p <RWUSER_PASS>,<RUSER_PASS>
OraDBI Performs the Following Tasks
• Interacts with the user to collect information about the name of Oracle account that will own the application schema (for example, CISADM), password of this account, and the name of the Oracle account that the application user will use (for example: CISUSER), and the name of the Oracle account that will be assigned read-only privileges to the application schema (for example, CISREAD).
• Connects to the database as CISADM account, checks whether the user already has the application schema installed to verify whether this is an initial installation.
• Verifies whether tablespace names already exist in the Storage.xml file (if not, the process will abort).
• Installs the schema, installs the system data, and configures security.
• Maintains upgrade log tables in the database.
• Updates release ID when the upgrade is completed successfully.
• If an error occurs while executing a SQL script or another utility, it logs and displays the error message and allows you to re-execute the current step. Log files OraDBI###.log are created in the same folder as OraDBI and contains all the SQL commands executed against the database along with the results. The log files are incremental so that the results are never overwritten. If warning messages are generated during the upgrade, OraDBI prompts the user at the end of the process. Users should check the log files to verify the warning messages.
• Warning messages are only alerts and do not necessarily mean a problem exists.
• Stores the Schema owner and password in the feature configuration table. The password is stored in encrypted format.
Post-installation Tasks
The post-installation tasks include:
Populating Language Data
For more information on running this batch program, refer to the Background Processes section in the Oracle Utilities Meter Solution Administrative User Guide included in this release. You can also install the language specific demo data packages (if available) into the database. Contact your Oracle representative to receive information on these packages.
Generating Database Statistics
During an install process, new database objects may be added to the target database. Before starting to use the database, generate the complete statistics for these new objects using the DBMS_STATS package.
Environment Registration
Note: If the target database is registered as a configuration laboratory or archiving database in another database, or another database has been registered as a configuration laboratory or archiving database in this database, it is required that you upgrade the registration at this stage.
The detailed instructions for environment registration can be found in the Oracle Utilities Market Settlements Management user documentation. Please refer to this documentation before executing the environment registration utility EnvSetup.exe included in the post-install folder.
Enabling USER_LOCK Package
For In-bound web services to work the USER_LOCK must be enabled at the database level. This is a one time step. If this is not already enabled, follow these steps to enable it.
1. Login as SYS user.
2. At the SQL prompt, run the following:
@?/rdbms/admin/userlock.sql
3. Grant permission.
grant execute on USER_LOCK to public;
Please note that grant can also be made to the database user which the Application connects to only instead of to public. For example, cisuser.
Creating Activity Statistics Materialized View
To improve the performance of drill down queries, use the following procedure to create the materialized view and then refresh the materialized view.
Navigate to .. /DB/MDM_V2.5.0.2.0/Post-Upgrade and run the scripts below.
1. Login as CISADM user.
Dropping Index D1T304S3 for Payload Statistic Functionality (Optional)
For an upgrade installation, this index already exists. If you are not using the Payload statistic functionality, or if you have no other SQL scripts referencing these fields, you may drop the index using the following SQL statement.
Connect to CISADM schema and execute the following:
DROP INDEX D1T304S3;
Populating the CI_INSTALL_PROD Table
After completing the Oracle Utilities Market Settlements Management database installation, navigate to ..\MDM.V2.5.0.2.0\Post-Upgrade, connect to the CISADM schema and run the following script:
@MSM_D1_Update.sql
Applying Patch 29049452
After completing the Oracle Utilities Market Settlements Management database installation, download the Patch 29049452 from My Oracle Support and apply it to the application. For more information, refer to the ReadMe included the patch installation package.
