Statistics Snapshot
This table describes the Statistics Snapshot maintenance object.
Table Name
Table Partitioning Type (Partitioning, Sub-Partitioning Key)
Index Name
Index Columns
Index Type (Global or Local)
Index Partitioning (Sub-Partitioning Key)
ILM_DT (Initial Load)
F1_STATS_
SNPSHT(Parent)
RANGE (ILM_DT,
SNAPSHOT_ID)
RANGE
(SNAPSHOT_ID)
F1_STATS_
SNPSHT.
CRE_DTTM
Reference Partitioning
F1C706P0
SNAPSHOT_ID
Global Partitioned
F1C706S1
BUS_OBJ_CD,BO_STATUS_CD,SNAPSHOT_ID
Global
CM_ILM_F1C706L0
ILM_DT,ILM_ARCH_SW
Local
F1_STATS_SNPSHT_CHAR
F1C707P0
SNAPSHOT_ID,CHAR_TYPE_CD,SEQ_NUM
Global Partitioned
F1C707S1
SRCH_CHAR_VAL
Global
F1_STATS_SNPSHT_LOG
F1C708P0
SNAPSHOT_ID,SEQNO
Global Partitioned
F1C708S1
CHAR_TYPE_CD,CHAR_VAL_FK1
Global
F1C708S2
Global
F1_STATS_SNPSHT_LOG_PARM
F1C709P0
SNAPSHOT_ID,SEQNO,PARM_SEQ
Global Partitioned
F1_STATS_SNPSHT_REL_OBJ
F1C710P0
SNAPSHOT_ID,STATS_SNPSHT_REL_OBJ_TYPE_FLG,SEQ_NUM
Global Partitioned
Activity
If sub retention periods will be defined for this MO, then please follow the guidelines set forth in section Module Specific ILM Implementation Details For Sub Retention.
This table describes the Activity maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_ACTIVITY (Parent)
RANGE (ILM_DT,
D1_ACTIVITY_ID)
Note: Default is to use sub-retention or use RANGE (ILM_DT, D1_ACTIVITY_ID) if not using sub-retention.
D1_ACTIVITY.
CRE_DTTM
D1T319P0
D1_ACTIVITY_ID
Global
Partitioned
RANGE
(D1_ACTIVITY_ID)
D1T319S0
BUS_OBJ_CD,
BO_STATUS_CD,
D1_ACTIVITY_ID
Global
Partitioned
HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_ACTIVITY_ID)
CM_ILM_D1T319S1
ILM_DT,
ILM_ARCH_SW,
D1_ACTIVITY_ID
Local
D1_ACTIVITY_CHAR
REFERENCE (D1_ACTIVITY_CHAR_FK)
D1T320P0
D1_ACTIVITY_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T320S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_ACTIVITY_
IDENTIFIER
REFERENCE (D1_ACTIVITY_IDENTIFIER_FK)
D1T330P0
D1_ACTIVITY_ID,
ACTIVITY_ID_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T330S0
ACTIVITY_ID_TYPE_
FLG, ID_VALUE
Global
Partitioned
HASH(ACTIVITY_
ID_TYPE_FLG, ID_VALUE)
D1T330S1
ACTIVITY_ID_TYPE_FLG, UPPER(ID_VALUE)
Global
D1_ACTIVITY_LOG
LOG_FK)
D1T321P0
D1_ACTIVITY_ID,
SEQNO
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T321S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_TYPE_CD, CHAR_VAL_FK1)
D1T321S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_TYPE_CD, CHAR_VAL)
D1_ACTIVITY_LOG_
PARM
REFERENCE (D1_ACTIVITY_LOG_PARM_FK)
D1T322P0
D1_ACTIVITY_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1_ACTIVITY_REL
REFERENCE (D1_ACTIVITY_REL_FK)
D1T323P0
D1_ACTIVITY_ID,
ACTIVITY_REL_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T323S0
REL_ACTIVITY_ID
Global
Partitioned
HASH(REL_
ACTIVITY_ID)
D1_ACTIVITY_REL_OBJ
REFERENCE (D1_ACTIVITY_REL_OBJ_
FK)
D1T324P0
D1_ACTIVITY_ID,
MAINT_OBJ_CD,
ACTIVITY_REL_OBJ_TYPE_FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T324S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Communication In
This table describes the Communication In maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_COMM_IN (Parent)
RANGE(ILM_DT, D1_COMM_ID)
D1_COMM_IN.
CRE_DTTM
D1T386P0
D1_COMM_ID
Global
Partitioned
RANGE (D1_COMM_ID)
D1T386S1
BUS_OBJ_CD,
BO_STATUS_CD,
D1_COMM_ID
Global
Partitioned
HASH(BUS_OBJ_CD,
BO_STATUS_CD, D1_COMM_ID)
CM_ILM_D1T386S1
ILM_DT,
ILM_ARCH_SW,
D1_COMM_ID
Local
D1_COMM_IN_CHAR
REFERENCE (D1_COMM_IN_CHAR_FK)
D1T387P0
D1_COMM_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE (D1_COMM_ID)
D1T387S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_COMM_IN_
IDENTIFIER
IDENTIFIER_FK)
D1T391P0
D1_COMM_ID,
COMM_ID_TYPE_FLG
Global
Partitioned
RANGE(D1_COMM_ID)
D1T391S0
COMM_ID_TYPE_FLG, ID_VALUE
Global
Partitioned
HASH(COMM_ID_TYPE_FLG, ID_VALUE)
D1T391S1
COMM_ID_TYPE_FLG, UPPER(ID_VALUE)
D1_COMM_IN_LOG
REFERENCE (D1_COMM_IN_LOG_FK)
D1T388P0
D1_COMM_ID,
SEQNO
Global
Partitioned
RANGE(D1_COMM_ID)
D1T388S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T388S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_COMM_IN_LOG_
PARM
REFERENCE (D1_COMM_IN_LOG_PARM_FK)
D1T389P0
D1_COMM_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_COMM_ID)
D1_COMM_IN_REL_OBJ
REFERENCE (D1_COMM_IN_REL_OBJ_
FK)
D1T390P0
D1_COMM_ID,
MAINT_OBJ_CD,
COMM_REL_OBJ_TYPE_FLG
Global
Partitioned
RANGE(D1_COMM_ID)
D1T390S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Communication Out
This table describes the Communication Out maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_COMM_OUT (Parent)
RANGE(ILM_DT,D1_COMM_ID)
D1_COMM_
OUT.
CRE_DTTM
D1T380P0
D1_COMM_ID
Global
Partitioned
RANGE (D1_COMM_ID)
D1T380S1
BUS_OBJ_CD,
BO_STATUS_CD,
D1_COMM_ID
Global
Partitioned
HASH(BUS_OBJ_CD,
BO_STATUS_CD,
D1_COMM_ID)
CM_ILM_D1T380S1
ILM_DT,
ILM_ARCH_SW,
D1_COMM_ID
Local
D1_COMM_OUT_CHAR
REFERENCE (D1_COMM_OUT_CHAR_FK)
D1T381P0
D1_COMM_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE (D1_COMM_ID)
D1T381S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_COMM_OUT_IDENTIFIER
REFERENCE (D1_COMM_OUT_IDENTIFIER_
FK)
D1T385P0
D1_COMM_ID,
COMM_ID_TYPE_FLG
Global
Partitioned
RANGE(D1_COMM_ID)
D1T385S0
Global
Partitioned
D1T385S1
D1_COMM_
OUT_LOG
REFERENCE (D1_COMM_OUT_LOG_FK)
D1T382P0
D1_COMM_ID,
SEQNO
Global
Partitioned
RANGE(D1_COMM_ID)
D1T382S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T382S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_COMM_OUT_LOG_PARM
REFERENCE (D1_COMM_OUT_LOG_PARM_FK)
D1T383P0
D1_COMM_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_COMM_ID)
D1_COMM_OUT_REL_OBJ
REFERENCE (D1_COMM_OUT_REL_OBJ_FK)
D1T384P0
D1_COMM_ID,
MAINT_OBJ_CD,
Global
Partitioned
RANGE(D1_COMM_ID)
D1T384S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Device Event
This table describes the Device Event maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index
Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_DVC_EVT (Parent)
RANGE(ILM_DT, DVC_EVT_ID)
Note: Default is to use sub-retention or use RANGE (ILM_DT,DVC_EVT_ID) if not using sub-retention.
D1_DVC_EVT.
CRE_DTTM
D1T400P0
DVC_EVT_ID
Global
Partitioned
RANGE (DVC_EVT_ID)
D1T400S1
BUS_OBJ_CD,
BO_STATUS_CD,
DVC_EVT_ID
Global
Partitioned
HASH(BUS_OBJ_CD, BO_STATUS_CD, DVC_EVT_ID)
D1T400S2
D1_DEVICE_ID,
DVC_EVT_DTTM
Global
Partitioned
HASH(D1_DEVICE_ID, DVC_EVT_DTTM)
D1T400S3
BUS_OBJ_CD,
BO_STATUS_CD,
D1_DEVICE_ID,
DVC_EVT_ID
Global
Partitioned
HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_DEVICE_ID, DVC_EVT_ID)
CM_ILM_D1T400S4
ILM_DT,
ILM_ARCH_SW,
DVC_EVT_ID
Local
D1_DVC_EVT_CHAR
REFERENCE (D1_DVC_EVT_
CHAR_FK)
D1T401P0
DVC_EVT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T401S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_DVC_EVT_
IDENTIFIER
IDENTIFIER_FK)
D1T405P0
DVC_EVT_ID,
DVC_EVT_ID_TYPE_FLG
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T405S0
DVC_EVT_ID_TYPE_FLG, ID_VALUE
Global
Partitioned
HASH(DVC_EVT_ID_TYPE_FLG, ID_VALUE)
D1T405S1
DVC_EVT_ID_TYPE_FLG, UPPER(ID_VALUE)
D1_DVC_EVT_LOG
REFERENCE (D1_DVC_EVT_LOG_FK)
D1T402P0
DVC_EVT_ID,
SEQNO
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T402S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T402S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_DVC_EVT_LOG_
PARM
REFERENCE (D1_DVC_EVT_LOG_PARM_FK)
D1T403P0
DVC_EVT_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(DVC_EVT_ID)
D1_DVC_EVT_REL_OBJ
REFERENCE (D1_DVC_EVT_REL_OBJ_FK)
D1T404P0
DVC_EVT_ID,
MAINT_OBJ_CD,
DVC_EVT_REL_OBJ_TYPE_FLG
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T404S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Completion Event
This table describes the Completion Event maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_COMPL_EVT (Parent)
RANGE(ILM_DT,COMPL_EVT_ID)
D1_COMPL_
EVT.
CRE_DTTM
D1T340P0
COMPL_EVT_ID
Global
Partitioned
RANGE (COMPL_EVT_ID)
D1T340S0
D1_ACTIVITY_ID
Global
Partitioned
HASH(D1_
ACTIVITY_ID)
CM_ILM_D1T340S1
ILM_DT,
ILM_ARCH_SW,
DVC_EVT_ID
Local
D1_COMPL_EVT_CHAR
REFERENCE (D1_COMPL_
EVT_CHAR_FK)
D1T341P0
COMPL_EVT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1T341S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_COMPL_EVT_LOG
REFERENCE (D1_COMPL_EVT_LOG_FK)
D1T342P0
COMPL_EVT_ID,
SEQNO
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1T342S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T342S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_COMPL_EVT_LOG_PARM
REFERENCE (D1_COMPL_EVT_LOG_PARM_FK)
D1T343P0
COMPL_EVT_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1_COMPL_EVT_REL_OBJ
REFERENCE (D1_COMPL_EVT_REL_OBJ_FK)
D1T344P0
COMPL_EVT_ID,
MAINT_OBJ_CD,
COMPL_EVT_REL_OBJ_TYP_FLG
Global
Partitioned
RANGE(COMPL_
EVT_ID)
D1T344S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
Initial Measurement Data
This table describes the Initial Measurement Data maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_INIT_MSRMT_DATA
(Parent)
RANGE (ILM_DT,MEASR_COMP_ID)
Note: Default is to use sub-retention or use RANGE (ILM_DT,MEASR_COMP_ID) if not using sub-retention.
D1_INIT_MSRMT_DATA.
CRE_DTTM
D1T304P0
INIT_MSRMT_DATA_ID
Global
Partitioned
RANGE (INIT_MSRMT_DATA_ID)
D1T304S1
MEASR_COMP_ID, BO_STATUS_CD, BUS_OBJ_CD, D1_TO_DTTM, D1_FROM_DTTM
Global Partitioned
RANGE (MEASR_COMP_
ID)
CM_ILM_D1T304S4
ILM_DT,
ILM_ARCH_SW,
INIT_MSRMT_DATA_ID
Local
D1_INIT_MSRMT_DATA_CHAR
REFERENCE (D1_INIT_MSRMT_DATA_CHAR_FK)
D1T305P0
INIT_MSRMT_DATA_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(INIT_MSRMT_DATA_ID)
D1T305S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_INIT_MSRMT_DATA_LOG
REFERENCE (D1_INIT_MSRMT_DATA_LOG_FK)
D1T306P0
INIT_MSRMT_DATA_ID,
SEQNO
Global
Partitioned
PARM
REFERENCE (D1_INIT_MSRMT_DATA_LOG_PARM_FK)
D1T307P0
INIT_MSRMT_DATA_ID,
SEQNO
PARM_SEQ
Global
Partitioned
Usage Transaction
This table describes the Usage Transaction maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_USAGE
(Parent)
RANGE(ILM_DT, D1_USAGE_ID)
D1_USAGE.
CRE_DTTM
D1T281P0
D1_USAGE_ID
Global
Partitioned
RANGE (D1_USAGE_ID)
D1T281S0
US_ID,
START_DTTM
Global
Partitioned
RANGE (US_ID)
D1T281S1
BUS_OBJ_CD,
BO_STATUS_CD,
D1_USAGE_ID
Global
Partitioned
HASH(BUS_OBJ_
CD, BO_STATUS_CD, D1_USAGE_ID)
CM_ILM_D1T281S2
ILM_DT,
ILM_ARCH_SW,
D1_USAGE_ID
Local
D1T419S1
USG_EXT_ID,
D1_USAGE_ID
Global
Partitioned
HASH (USG_EXT_ID)
D1_USAGE_
CHAR
REFERENCE (D1_USAGE_
CHAR_FK)
D1T285P0
D1_USAGE_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1T285S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_USAGE_LOG
REFERENCE (D1_USAGE_LOG_FK)
D1T286P0
D1_USAGE_ID,
SEQNO
Global
Partitioned
RANGE(D1_USAGE_ID)
D1T286S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T286S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_USAGE_LOG_PARM
REFERENCE(D1_USAGE_LOG_
PARM_FK)
D1T287P0
D1_USAGE_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE (D1_USAGE_ID)
D1_USAGE_
PERIOD
REFERENCE(D1_USAGE_PERIOD_FK)
D1T283P0
D1_USAGE_ID,
PERIOD_SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1_USAGE_
PERIOD_ITEM_DET
REFERENCE(D1_USAGE_PERIOD_ITEM_DET_FK)
D1T431P0
D1_USAGE_ID,
PERIOD_SEQ_NUM,
ITEM_SEQ_NUM
Global
Partitioned
RANGE(D1_USAGE_ID)
D1_USAGE_
PERIOD_SQ
REFERENCE(D1_USAGE_PERIOD_SQ_FK)
D1T284P0
D1_USAGE_ID,
PERIOD_SEQ_NUM,
SQ_SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1_USAGE_PERIOD_SQ_DATA
REFERENCE(D1_USAGE_PERIOD_SQ_DATA_FK)
D1T497P0
D1_USAGE_ID,
PERIOD_SEQ_NUM,
SQ_SEQ_NUM,
SQ_DATA_DTTM
Global Partitioned
RANGE(D1_
USAGE_ID)
D1_USAGE_REL
REFERENCE (D1_USAGE_REL_FK)
D1T316P0
D1_USAGE_ID,
USAGE_REL_TYPE_FLG
Global
Partitioned
RANGE(D1_
USAGE_ID)
D1T316S0
REL_USAGE_ID,
USAGE_REL_TYPE_FLG,
D1_USAGE_ID
Global
Partitioned
HASH(REL_USAGE_ID,
USAGE_REL_TYPE_FLG,
D1_USAGE_ID)
D1_USAGE_
SCALAR_DTL
REFERENCE(D1_USAGE_SCALAR_DTL_FK)
D1T282P0
D1_USAGE_ID,
D1_SP_ID,
SEQ_NUM
Global
Partitioned
RANGE(D1_
USAGE_ID)
Usage Transaction Exception
This table describes the Usage Transaction Exception maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_USAGE_
EXCP (Parent)
RANGE (ILM_DT,
USAGE_EXCP_ID)
D1_USAGE_
EXCP.
CRE_DTTM
D1T443P0
USAGE_EXCP_ID
Global Partitioned
RANGE
(USAGE_EXCP_
ID)
CM_ILM_D1T443S1
ILM_DT,
ILM_ARCH_SW,
USAGE_EXCP_ID
Local Partitioned
D1_USAGE_
EXCP_CHAR
EXCP_CHAR_
FK)
D1T446P0
USAGE_EXCP_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
RANGE
(USAGE_EXCP_
ID)
D1T446S1
SRCH_CHAR_VAL
Global Partitioned
HASH
(SRCH_CHAR_
VAL)
D1_USAGE_
EXCP_PARM
EXCP_PARM_
FK)
D1T445P0
USAGE_EXCP_ID,
PARM_SEQ
Global Partitioned
RANGE
(USAGE_EXCP_
ID)
VEE Exception
This table describes the VEE Exception maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_VEE_EXCP (Parent)
RANGE(ILM_DT, VEE_EXCP_ID)
D1_VEE_EXCP.
CRE_DTTM
D1T308P0
VEE_EXCP_ID
Global
Partitioned
RANGE (VEE_EXCP_ID)
D1T308S1
INIT_MSRMT_DATA_ID
Global
Partitioned
HASH(INIT_
MSRMT_DATA_ID)
CM_ILM_D1T308S2
ILM_DT,
ILM_ARCH_SW,
VEE_EXCP_ID
Local
D1_VEE_EXCP_CHAR
REFERENCE (D1_VEE_EXCP_
CHAR_FK)
D1T310P0
VEE_EXCP_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(VEE_
EXCP_ID)
D1T310S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_VEE_EXCP_PARM
PARM_FK)
D1T309P0
VEE_EXCP_ID,
PARM_SEQ
Global
Partitioned
RANGE(VEE_
EXCP_ID))
Snapshot Tables
This table below describes the snapshot tables.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_SP_SNAP_DL
RANGE(ILM_DT, SP_SNAP_ID)
D1_SP_SNAP_DL.SNAPSHOT_
DTTM
D1T434P0
SP_SNAP_ID
Global Partitioned
RANGE(SP_SNAP_ID)
D1T434S0
D1_SP_ID,
SNAPSHOT_DTTM,
SNAPSHOT_TYPE_FLG
Global
CM_ILM_D1T434S1
ILM_DT,
ILM_ARCH_SW,
SP_SNAP_ID
Local
D1_SP_UNR_
USG_SNAP_DL
RANGE(ILM_DT, SP_UNR_USG_
SNAP_ID)
D1_SP_UNR_USG_SNAP_DL.SNAPSHOT_DTTM
D1T438P0
SP_UNR_USG_SNAP_ID
Global Partitioned
RANGE(SP_UNR_USG_SNAP_ID)
D1T438S0
D1_SP_ID, SNAPSHOT_DTTM, UNR_USG_SNAPSHOT_
TYPE_FLG, SNAPSHOT_TYPE_FLG
Global
CM_ILM_D1T438S1
ILM_DT,
ILM_ARCH_SW, SP_UNR_USG_SNAP_ID
Local
D1_SP_USG_
SNAP_DL
RANGE(ILM_DT, SP_USG_SNAP_
ID)
D1_SP_USG_SNAP_DL.SNAPSHOT_DTTM
D1T436P0
SP_USG_SNAP_ID
Global Partitioned
RANGE(SP_USG_
SNAP_ID)
D1T436S0
D1_SP_ID,
SNAPSHOT_DTTM,
MEASR_COMP_ID,
USG_SNAPSHOT_TYPE_FLG,
D1_TOU_CD,
MSRMT_COND_FLG,
SNAPSHOT_TYPE_FLG
Global
CM_ILM_D1T436S1
ILM_DT,
ILM_ARCH_SW,
SP_USG_SNAP_ID
Local
D1_SP_VEE_
EXCP_SNAP_DL
RANGE(ILM_DT, SP_VEE_EXCP_
SNAP_ID)
D1_SP_VEE_
EXCP_SNAP_
DL.SNAPSHOT_
DTTM
D1T440P0
SP_VEE_EXCP_SNAP_ID
Global Partitioned
RANGE(SP_VEE_
EXCP_SNAP_ID)
D1T440S0
D1_SP_ID,
SNAPSHOT_DTTM,
MEASR_COMP_ID,
EXCP_TYPE_CD,
D1_IMD_TYPE_FLG,
EXCP_SEVERITY_FLG,
VEE_GRP_CD,
VEE_RULE_CD,
SNAPSHOT_TYPE_FLG
Global
CM_ILM_D1T440S1
ILM_DT,
ILM_ARCH_SW,
SP_VEE_EXCP_SNAP_ID
Local
Initial Measurement Snapshot
This table below describes the Initial Measurement Snapshot maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_INIT_MSRMT_SNAP (Parent)
Range(ILM_DT, INIT_MSRMT_
SNAP_ID)
D1T622P0
INIT_MSRMT_SNAP_ID
Global Partitioned
Range(INIT_
MSRMT_SNAP_ID)
D1_INIT_MSRMT_SNAP.CRE_
DTTM
CM_ILM_D1T622L0
ILM_DT,
ILM_ARCH_SW,
INIT_MSRMT_SNAP_ID
Local Partitioned
D1_INIT_MSRMT_SNAP_CHAR
D1T624P0
INIT_MSRMT_SNAP_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global Partitioned
D1_INIT_MSRMT_SNAP _LOG
D1T625P0
INIT_MSRMT_SNAP_ID,
SEQNO
Global Partitioned
D1_INIT_MSRMT_SNAP _LOG_PARM
D1T626P0
INIT_MSRMT_SNAP_ID,
SEQNO,
PARM_SEQ
Global Partitioned
Measurement Data Snapshot Interval
This table below describes the Measurement Data Snapshot Interval maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_MDSI
(Parent)
Range(ILM_DT, D1_MDSI_ID)
D1T565P0
D1_MDSI_ID
Global Partitioned
Range(D1_MDSI_
ID)
D1_MDSI_
START_DTTM
CM_ILM_D1T565L0
ILM_DT,
ILM_ARCH_SW,
D1_MDSI_ID
Local Partitioned
Measurement Data Snapshot Scalar
This table below describes the Measurement Data Snapshot Scalar maintenance object.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_MDSS
(Parent)
Range(ILM_DT, D1_MDSS_ID)
D1T594P0
D1_MDSS_ID
Global Partitioned
Range(D1_MDSS_ID
D1_MDSS_
START_DTTM
CM_ILM_D1T594L0
ILM_DT,
ILM_ARCH_SW,
D1_MDSS_ID
Local Partitioned
This section outlines each maintenance object that has been configured to support ILM as well as sub retention periods. This differs from the standard ILM enabled tables in that the partitioning strategy is inclusive of an additional column that defines the retention period for each record. In each case, the recommendation of the initial load of the ILM_DT and the <field name for retention period> for existing records is noted. The CTAS operation for these tables includes an extra step of generating a temporary mapping table that will allow the select for the ILM_DT to also identify the appropriate <retention period field name> for each record.
This section details the following maintenance objects that support ILM as well as sub retention periods:
Activity
If sub retention periods will not be defined for this MO, then please follow the guidelines set forth in section Module Specific ILM Implementation Details.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
RANGE (ILM_DT, RETENTION_
PERIOD)
D1_ACTIVITY.
CRE_DTTM
D1T319P0
D1_ACTIVITY_ID
Global
Partitioned
RANGE
(D1_ACTIVITY_ID)
D1T319S0
BUS_OBJ_CD,
BO_STATUS_CD,
D1_ACTIVITY_ID
Global
Partitioned
CM_ILM_D1T319S1
ILM_DT,
RETENTION_PERIOD,
ILM_ARCH_SW,
D1_ACTIVITY_ID
Local
D1_ACTIVITY_CHAR
CHAR_FK)
D1T320P0
D1_ACTIVITY_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T320S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_ACTIVITY_
IDENTIFIER
D1T330P0
D1_ACTIVITY_ID,
ACTIVITY_ID_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T330S0
ACTIVITY_ID_TYPE_
FLG, ID_VALUE
Global
Partitioned
HASH(ACTIVITY_ID_TYPE_FLG, ID_VALUE)
D1T330S1
ACTIVITY_ID_TYPE_
D1_ACTIVITY_LOG
LOG_FK)
D1T321P0
D1_ACTIVITY_ID,
SEQNO
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T321S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
D1T321S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
D1_ACTIVITY_LOG_
PARM
D1T322P0
D1_ACTIVITY_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1_ACTIVITY_REL
D1T323P0
D1_ACTIVITY_ID,
ACTIVITY_REL_TYPE_
FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T323S0
REL_ACTIVITY_ID
Global
Partitioned
HASH(REL_
ACTIVITY_ID)
D1_ACTIVITY_REL_OBJ
REFERENCE (D1_ACTIVITY_REL_OBJ_FK)
D1T324P0
D1_ACTIVITY_ID,
MAINT_OBJ_CD,
ACTIVITY_REL_OBJ_
TYPE_FLG
Global
Partitioned
RANGE(D1_
ACTIVITY_ID)
D1T324S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
PK_VALUE3,
PK_VALUE4)
Query for Setting the Retention Period
The following query should be used to create a temporary table to create a mapping table that will identify the retention period for each measuring component type. This table will then be used during in the CTAS operation for Activity to identify the retention period for each record.
Please refer to Sample SQL for Enabling ILM with Sub Retention in MSM (Existing Installation) for detailed information using Initial Measurement Data as an example.
Note: A pre-requisite to executing this query is configuring the appropriate retention periods in the ILM master configuration in the Oracle Utilities Meter Data Management application.
/*****ACTIVITY*****/
CREATE TABLE ILM_ACTIVITY_RETENTION_TMP
AS
select acty.activity_type_cd
/*retrieve the retention period for Activity Types in this order of precedence:
1. The category based retention period from the MDM master configuration
2. The MO level retention period from the MO options
3. The installation level retention period from the FW master configuration
, CAST(coalesce(catMap.retPeriod --Category level
, (select maint_obj_opt_val
from ci_md_mo_opt mmo
where maint_obj_cd = 'D1-ACTIVITY'
and maint_obj_opt_flg ='FLRP'
and seq_num =
(select max(seq_num)
and maint_obj_opt_flg ='FLRP')) --MO level
, extractvalue( xmlparse(content fw_mcfg.mst_config_data)
,'generalMasterConfiguration/defaultRetentionPeriod') --Install level
) as NUMBER(5)) retPeriod
from d1_activity_type acty
, (select extractvalue(value(p),
'activityTypeCategoryRetentionPeriodList/activityTypeCategory'
)ACTIVITY_TYPE_CAT_FLG
, extractvalue(value(p),
'activityTypeCategoryRetentionPeriodList/retentionPeriod'
)retPeriod
from f1_mst_config mdm_mcfg ,
table(xmlsequence(extract(xmlparse(content mdm_mcfg.mst_config_data),
'activityRetentionPeriod/activityTypeCategoryRetentionPeriods/activityTypeCategoryRetentionPeriodList'
))) p
where mdm_mcfg.bus_obj_cd = 'D1-ILMMSConfig')catMap
, f1_mst_config fw_mcfg
where fw_mcfg.bus_obj_cd = 'F1-ILMMSConfig'
and acty.ACTIVITY_TYPE_CAT_FLG = catMap.ACTIVITY_TYPE_CAT_FLG (+)
order by 1;
Device Event
Note: If sub retention periods will not be defined for this MO, then please follow the guidelines set forth in section Module Specific ILM Implementation Details.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_DVC_EVT
(Parent)
RANGE(ILM_DT, RETENTION_
PERIOD)
D1_DVC_EVT.
CRE_DTTM
D1T400P0
DVC_EVT_ID
Global
Partitioned
RANGE (DVC_EVT_ID)
D1T400S1
BUS_OBJ_CD,
BO_STATUS_CD,
DVC_EVT_ID
Global
Partitioned
D1T400S2
D1_DEVICE_ID,
DVC_EVT_DTTM
Global
Partitioned
D1T400S3
BUS_OBJ_CD,
BO_STATUS_CD,
D1_DEVICE_ID,
DVC_EVT_ID
Global
Partitioned
CM_ILM_D1T400S4
ILM_DT,
RETENTION_PERIOD,
ILM_ARCH_SW,
DVC_EVT_ID
Local
D1_DVC_EVT_
CHAR
CHAR_FK)
D1T401P0
DVC_EVT_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T401S0
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1_DVC_EVT_
IDENTIFIER
IDENTIFIER_FK)
D1T405P0
DVC_EVT_ID,
DVC_EVT_ID_TYPE_FLG
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T405S0
Global
Partitioned
D1T405S1
D1_DVC_EVT_LOG
D1T402P0
DVC_EVT_ID,
SEQNO
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T402S1
CHAR_TYPE_CD,
CHAR_VAL_FK1
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL_FK1)
D1T402S2
CHAR_TYPE_CD,
CHAR_VAL
Global
Partitioned
HASH(CHAR_
TYPE_CD,
CHAR_VAL)
D1_DVC_EVT_LOG_PARM
D1T403P0
DVC_EVT_ID,
SEQNO
PARM_SEQ
Global
Partitioned
RANGE(DVC_EVT_ID)
D1_DVC_EVT_REL_OBJ
REL_OBJ_FK)
D1T404P0
DVC_EVT_ID,
MAINT_OBJ_CD,
Global
Partitioned
RANGE(DVC_EVT_ID)
D1T404S0
PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4,
PK_VALUE5,
MAINT_OBJ_CD
Global
Partitioned
HASH(PK_VALUE1,
PK_VALUE2,
PK_VALUE3,
PK_VALUE4)
The following query should be used to create a temporary table to create a mapping table that will identify the retention period for each measuring component type. This table will then be used during in the CTAS operation for Device Event to identify the retention period for each record.
Note: A pre-requisite to executing this query is configuring the appropriate retention periods in the ILM master configuration in the Oracle Utilities Market Settlements Management application.
CREATE TABLE ILM_DVC_EVT_RETENTION_TMP
AS
select det.dvc_evt_type_cd
/*retrieve the retention period for Device Event Types in this order of precedence:
where maint_obj_cd = 'D1-DVCEVENT'
and seq_num = (select max(seq_num)
fw_mcfg.mst_config_data),
from d1_dvc_evt_type det
'deviceEventCategoryRetentionPeriodList/deviceEventCategory') dvc_evt_cat_flg
'deviceEventCategoryRetentionPeriodList/retentionPeriod') retPeriod
'deviceEventRetentionPeriod/deviceEventCategoryRetentionPeriods/deviceEventCategoryRetentionPeriodList'
))) p
and det.dvc_evt_cat_flg = catMap.dvc_evt_cat_flg (+)
order by 1;
If sub retention periods will not be defined for this maintenance object, follow the guidelines mentioned in the Module Specific ILM Implementation Details section.
Table Name
Table Partitioning
Type
(Partitioning,
Sub-Partitioning
Key)
Index Name
Index Columns
Index Type
Global or
Local
Index
Partitioning
Sub-Partitioning
Key
ILM_DT
Initial Load
D1_INIT_MSRMT_DATA
(Parent)
PERIOD)
D1_INIT_MSRMT_DATA.
CRE_DTTM
D1T304P0
INIT_MSRMT_DATA_ID
Global
Partitioned
D1T304S1
MEASR_COMP_ID,
BO_STATUS_CD,
BUS_OBJ_CD,
D1_TO_DTTM,
D1_FROM_DTTM
Global
Partitioned
RANGE (MEASR_COMP_ID)
CM_ILM_D1T304S4
ILM_DT,
RETENTION_PERIOD,
ILM_ARCH_SW,
INIT_MSRMT_DATA_ID
Local
D1T305P0
INIT_MSRMT_DATA_ID,
CHAR_TYPE_CD,
SEQ_NUM
Global
Partitioned
D1T305S1
SRCH_CHAR_VAL
Global
Partitioned
HASH(SRCH_CHAR_VAL)
D1T306P0
INIT_MSRMT_DATA_ID,
SEQNO
Global
Partitioned
PARM
D1T307P0
INIT_MSRMT_DATA_ID,
SEQNO
PARM_SEQ
Global
Partitioned
The following query should be used to create a temporary table to create a mapping table that will identify the retention period for each measuring component type. This table will then be used during in the CTAS operation for Initial Measurement Data to identify the retention period for each record.
Please refer to Sample SQL for Enabling ILM in MSM (Existing Installation) for detailed information using Initial Measurement Data as an example.
CREATE TABLE ILM_IMD_RETENTION_TMP
AS
select mct.measr_comp_type_cd
/*retrieve the retention period for MC Types in this order of precedence:
1. The UOM based retention period from the MDM master configuration
2. The interval IMD retention period from the MDM master configuration
3. The MO level retention period from the MO options
4. The installation level retention period from the FW master configuration
, CAST(coalesce( (select retPeriod
from (select 'D1IN' interval_scalar_flg
, extractvalue(value(p),'uomRetentionPeriodList/uom') D1_UOM_CD
, extractvalue(value(p),'uomRetentionPeriodList/retentionPeriod') retPeriod
, table(xmlsequence(extract(xmlparse(content
'imdRetentionPeriod/intervalImdRetentionPeriods/uomRetentionPeriods/uomRetentionPeriodList'))) p
union
select 'D1SC' INTERVAL_SCALAR_FLG
'imdRetentionPeriod/scalarImdRetentionPeriods/uomRetentionPeriods/uomRetentionPeriodList'))) p
where mdm_mcfg.bus_obj_cd = 'D1-ILMMSConfig') uomMap
where uomMap.interval_scalar_flg = mct.interval_scalar_flg
and trim(mctvi.d1_uom_cd) = trim(uomMap.d1_uom_cd))--UOM
, DECODE(mct.interval_scalar_flg
,'D1IN'
,extractvalue( xmlparse(content mdm_mcfg.mst_config_data),
'imdRetentionPeriod/intervalImdRetentionPeriods/intervalRetentionPeriod') --interval IMD
'imdRetentionPeriod/scalarImdRetentionPeriods/scalarRetentionPeriod') --scalar IMD
where maint_obj_cd = 'D1-IMD'
and maint_obj_opt_flg ='FLRP')) --IMD
, extractvalue( xmlparse(content fw_mcfg.mst_config_data),
from d1_measr_comp_type mct
, d1_mc_type_value_identifier mctvi
, f1_mst_config mdm_mcfg
where mct.measr_comp_type_cd = mctvi.measr_comp_type_cd
and mctvi.value_id_type_flg = 'D1MS'
and fw_mcfg.bus_obj_cd = 'F1-ILMMSConfig'
and mdm_mcfg.bus_obj_cd = 'D1-ILMMSConfig'
order by 1;
On-going Maintenance Phase
The following steps provide a high level overview of what needs to be done for on-going maintenance for ILM on enabled MOs.
Please refer to the Sample SQL for Periodic Maintenance for detailed information using To Do Entry (Without LOB), F1_SYNC_REC_IN(With LOB-Tablespace per Partition), Initial Measurement Data (With LOB-Tablespace per Subpartition), and the D1_MSRMT table (Partition Compression) as examples.
1. Add the partition:
a. Create Tablespace to be used for the new parent table partition.
b. Since, we define MAXVALUE Partition; new partition can only be created using “SPLIT” operation. Identify and use next HIGH_VALUE Partition for the split operation.
c. All the child table(s) partition(s)\LOB(s) must be altered to use the same tablespace as that of the parent table’s partition.
d. Enable advanced compression on all child table(s).
e. Copy partition level statistics from the previous partition.
2. Archive the partition/subpartition:
a. Make the tablespace that will be archived READ ONLY.
b. Check that no records have ILM_ARCH_SW = ‘N’.
• If record count is zero, then proceed for further steps.
• If record count is not zero, then change the tablespace back to READ WRITE MODE as Archive is not Feasible at the time.
c. Create an archive tablespace for the partition/subpartition that needs to be archived.
d. Create staging tables using the new archive tablespace. Load data for all child tables first.
e. Create staging table using the new archive tablespace and load data for the parent table.
f. Export tablespace using TRANSPORT_TABLESPACES method.
Make Sure Tablespace datafile required for further import is preserved.
g. Drop the partition, partition the tablespace and archive the tablespace (as it is already exported).
3. Restore the partition:
a. Create a new tablespace to restore the partition/subpartition.
b. Add partition using split operation on next greater high value partition.
If the table contains LOBS, there will an additional statement in split partition DDL indicating tablespace where the LOBs will be stored.
c. Enable advanced compression on all child table(s).
d. Import Tablespace using TRANSPORT_TABLESPACES method.
e. Load data into the parent table first from the staging table.
f. Load data into the child table from the staging table.
g. Drop the archive tablespace after import and data loading is successful.
4. Compress D1_MSRMT table Partition:
a. Create new compressed tablespace.
b. Create a table using CTAS for each subpartition of the partition being compressed in the new compressed tablespace.
c. Create a unique primary index for each subpartition of the partition being compressed in the new compressed tablespace. Then alter table to create the primary key.
d. Exchange the subpartition of the D1_MSRMT table with the newly created table for each subpartition.
e. Drop the original uncompressed tablespace.
f. Alter the partition level metadata to reflect the new compressed tablespace.
g. Rename the new compressed tablespace to the original tablespace name.
5. Move Data between different storage tiers:
The ILM facilities can be used within the database to implement storage savings, as follows:
• Use ILM Assistant to define the data groups to be used for the individual objects. Assign those data groups to partitions and storage devices to implement the storage savings. Remember to assign transportable tablespaces for the archive/dormant data stage to allow for safe removal of the data.
• Use ILM assistant to generate the necessary commands to implement the data changes manually or use Automatic Storage Management (ASM) to automate the data storage policies.
• Optionally, use Automatic Data Optimization to provide further optimizations.
For more information about ILM refer to the following:
• Oracle Database VLDB and Partitioning Guide (19c) available at:
• Oracle Enterprise Manager 13.4 Lifecycle Management:
