Conversion Tools
This chapter describes the following database conversion tools:
• Upgrading the Production Database
Note that all database related single fixes and service packs need to be applied against the production schema. Staging schema should not be updated with database single fixes or service packs. Staging schema need to be rebuilt for any fixes that contain DDL to create new database objects in production schema.
