Schema Nodes and Attributes
The Four Element Types
A schema element can be one of four different structure types. Note that there are two classes of element types: the structural nodes group and list, and the data containing nodes of field and raw.
| Mnemonic | Valid Values | Description | Examples |
| type= | "field" |
 The field type is the default type for any element not explicitly labeled as something other than a field. Therefore, you virtually never have to explicitly label an element as a field. Note that a field element, unlike group or list, will contain information in its nodes - rather than other nodes.  |
| "group" |
 The group element is typically a structural element of the schema only, in which case it has no mapping. Note that when grouping several elements that are all used to map an XML structure of a CLOB / XML field of a business object driven record, the mapping may be at the group level.  |
 Example where a group is used to create a structure
Example where the group includes the mapping:
| "list" |
 The list node is structural node like the group node. The only difference is that the list structure has the ability to repeat multiple times in an XML document.  |
 Example of a schema with a list:
| "raw" |
 The raw data type is used to capture a chunk of raw text that doesn't have any inherent structure associated with it.  |
Example of an XML instance for the above schema:
The Data Type of a Field Element
Of the four different element types, only a field can have a data type.
| dataType= | "string" |
 By default, a field element is a string. Therefore, there is no requirement to specify the string data type.  |
| "number" |
 Defines an element that is a number. Note:
UI hints include
a setting to Suppress Automatic Number Formatting. Note:
Use currencyRef attribute for auto-display of currency symbol that is associated
with the referenced currency code. The currency decimal positions
are ignored by this formatting allowing you to display a currency
symbol for a unit rate with many decimals.  |
 Examples
"money"
 Optional additional attributes currencyRef="element name" |
 Defines an element that represents a monetary amount. The currency reference is optional and if left blank the installation currency will be used. Automatic formatting and validation to be applied based on the currency. For example, the currency symbol will be shown when auto-rendering. In addition, the number of decimal places must not exceed the valid number defined for the currency. Note:
Refer
to Referencing
Other Elements for supported syntax for referring to other
elements.   |
"lookup"
 Required additional attribute lookup="field name" |
 Defines an element that has valid values defined using a lookup. The lookup field is required.  |
"lookupBO"
 Required additional attribute lookupBO="bo name" |
 Defines an element that has valid values defined using an extendable lookup. The extendable lookup's business object is required.  |
| "boolean" |
 Defines an element that has values of "Y" and "N".  |
| "date" |
 Defines an element that represents a date.  |
 "dateTime"  |
 Defines an element that represents a date and time. Note:
Refer to Standard Time Considerations for additional
configuration available for date / time fields that represent standard
time.  |
| "time" |
 Defines an element that represents a time.  |
| "uri" |
 Defines an element captures a URI. Elements defined with this type enable the support for URI Allowlist and Substitution as described in Referencing URIs .  |
Referencing Other Elements
There are several attributes that allow for a reference to another element in the same schema. The supported syntax of the XPath reference is the same in every case. This section provides examples using the default reference attribute (defaultRef).
Reference a sibling element:
<schema>
   <id mapField="ACCT_ID" required="true"/>
   <altId defaultRef="id" required="true"/>
</schema>
Reference an element in a higher group:
<schema>
   <msgInfo type="group" mapXML="XML_FIELD">
     <altId defaultRef="../id" required="true"/>
   </msgInfo>
</schema>
Reference an element in a lower group:
<schema>
   <id mapField="ACCT_ID" defaultRef="msgInfo/altId" required="true"/>
     <altId required="true"/>
   </msgInfo>
</schema>
Reference an element in another group:
<schema>
  <acctInfo type="group">
  </acctInfo>
     <altId defaultRef="../acctInfo/altId" required="true"/>
   </msgInfo>
</schema>
Legal vs. Standard Time Considerations
Most date / time fields represent "legal" time such that if a time zone changes their clocks for winter and summer time, the date / time field captures the current observed time. However, some date / time fields should always be captured in standard time to avoid confusion / ambiguity. A good example is a date and time related to detailed interval data. Refer to Designing Time Zones for more information.
When defining an element with dataType="dateTime", you may use legalTime="true" to indicate that data captured in the element always represents legal time in the 'base' time zone, or use stdTime="true" to indicate that data is stored in standard time in the 'base' time zone. The 'base' time zone is specified on the Installation options.
Example:
<schema>
  <startTimeS dataType="dateTime" stdTime="true"/>
  <startTimeL dataType="dateTime" legalTime="true"/>
</schema>
If the time zone that represents the date / time field is not the installation time zone, use the optional setting stdTimeRef="XPath to time zone element" to indicate that the element represents standard time and indicates the time zone to use. Use legalTimeRef= when the element is stored in legal time. Refer to Referencing Other Elements for supported syntax for referring to other elements.
Example:
<schema>
  <alternateTimeZone fkRef="F1-TZONE" suppress="true"/>
  <startDateTimeS dataType="dateTime" stdTimeRef="alternateTimeZone"/>
  <startDateTimeL dataType="dateTime" legalTimeRef="alternateTimeZone"/>
</schema>
There may be cases where the date / time is captured in one time zone, but should be displayed using a different time zone. In this case, the attribute displayRef="XPath" may be used in addition to the appropriate attribute that identifies the time zone that the data is capture in. Refer to Referencing Other Elements for supported syntax.
<schema>
  <displayTimeZone fkRef="F1-TZONE" suppress="true"/>
  <startDateTimeS dataType="dateTime" stdTime="true" displayRef="displayTimeZone"/>
  <startDateTimeL dataType="dateTime" legalTime="true" displayRef="displayTimeZone"/>
</schema>
The Mapping Attributes
When constructing your schema, you can choose from one of the following mapping attributes.
| mapField= | "field name" |
 In the case of a business object, the mapField attribute is used to identify the database column the element is related to. For business service schemas, the mapField= attribute is used to link a schema element with a service element.  |
| mapChild= | "table name" |
 The mapChild attribute is used only for business object mapping. It is used in two ways:
Example of a list within a child table in a BO:
| mapList= | "list name" |
 The mapList attribute is used only for business service mapping. It is used in two ways:
Example of a list within a business service:
| mapXML= | "field name" |
 The mapXML attribute is typically used to map XML structures into a large character / XML field of the service. Note that when you use mapXML to map either a list or group structure (type="list" or type="group") you don't have to map all the child elements within the structure. It is also possible to map list elements to a large character field associated with the list child.  |
| isPrimeKey= | "true" |
 You must specify a primary key for a list defined within a mapped XML element (type="list" mapXML="CLOB"). The primary key is used by the framework to determine whether a list element add, update or delete is required during a business object update. Note:
You do not need to specify
the prime key for a business object list mapped to maintenance object
list.  When a physical list is mapped, the prime key is derived from
existing physical meta-data.  |
| orderBy= | "XPath asc|desc, XPath asc|desc" |
 By default, a list defined within a mapped XML element (type="list" mapXML="CLOB") is sorted by the first element of the list. A different sort order may be specified using the orderBy attribute. The attribute value is a comma separated list of field XPaths (relative to the list element) with an optional sort order (ascending is the default). Note:
This is only available for lists mapped as
XML within business objects.  |
Descriptive Attributes
The following attributes can be used to describe a schema element and provide additional configuration related to the element. Typically, these attributes are useful for field elements only.
| <!-- comment --> |
 Use this to add a comment to a schema by using special open and close characters: <!-- and -->.  |
| description= | "text" |
 The description of an element may be used to provide an internal description of the element to help a reader of the schema to understand the business reason for the element.  |
| label= | "text" |
 The label of an element is meant to be a short bit of verbiage that would typically precede the element in a user interface.  |
| required= | "true" |
 Used to require the existence of an element during object interaction. Note:
For included schemas,
the required="true" attribute is not processed on business object
and business service schemas when they are included within a service
script schema.  This is to support the ability of the service script
to populate required elements before an embedded business object or
business service is invoked from the service script.  |
| mdField= | "field code" |
 The meta-data field attribute is used to associate an element with a field's metadata. The field defines data type, as well as its label and help text. If you link an element with a meta-data field, you don't need to specify any of these attributes. Note:
For a business object schema, the mapField attribute is used to derive
the data type and label. An mdField attribute may be provided to override
these attributes, if needed. If the element is mapped to an XML column,
the mdField is needed to provide the appropriate data type and label.  |
| fkRef= | "FK Reference Code" |
 If the element is a foreign key, defining its FK Reference will enable framework validation of the element during schema interaction and automatically provide descriptions and navigation capability.  |
| private= | "true" |
 Marking an element as private will prevent it from being exposed in schema interaction. Note:
A private element requires
a default.  |
| suppress= | "true" |
 This setting prevents an element from appearing in automatically generated user interfaces. Note:
This attribute can be specified
on a group, in which case all elements of the group will be suppressed. Note:
Refer to Defaulting and
System Variables for advice related to default values for suppressed
elements.  |
| "blank" |
 This setting means that automatic UI rendering in display mode will hide the element if its value is blank. The element will still be modifiable on the input map whether blank or not.  |
| "input" |
 This setting means that automatic UI rendering will suppress the element for input, although it may still be displayed if it is not blank. Note:
Elements marked as suppress="input" will behave as
with suppress="blank". If the value is blank, no value will be displayed on either the
display or input map.  If the element's value is present, then the
element will be displayed on both the display and input map. Note:
elements.  |
| noAudit= | "true" |
 This setting prevents an element from appearing as a changed element in the business object's audit plug-in spot. If specified on a group or list node it applies to the whole node. You cannot specify it on the schema root node, only on schema elements. Note:
This attribute is only applicable to business object schemas.  |
| storeEmptyNodes= | "true" |
 By default, empty nodes are removed from a business object instance when saved. This setting allows a group or a list element to explicitly keep its empty nodes. This attribute may be useful in situations where business object data is exchanged with an external system and there is a need to distinguish between an empty value for an element that participates in the synchronization and an element that does not participate and therefore omitted from the message altogether. Note:
This is only available for group and list elements.  |
| emitEmptyGroups= | "true" |
 By default, empty nodes are not included in the output of a business object or a business service call. This attribute is set at the top level schema node, allowing empty nodes of all groups and list elements to be included in the output. This attribute may be useful in the same situations that may require the use of the storeEmptyNodes= attribute. Note:
for business object and business service schemas.  |
| emitEmptyElements= | "true" |
 This attribute is similar to the emitEmptyGroups= attribute but may also be specified at the field level. The attribute is applicable to all schema types.  |
| adheresToDA= | “comma separated list of data area names.” |
 This attribute is applicable to the schema, group and list nodes. It claims that this sub-schema node is intended to "look like" the schema of one of the listed data areas, for polymorphism reasons in general. Note:
The recommended approach for enforcing the structure
of a shared data area is by including it in the schema. This attribute
should be limited to use cases where the ability to include the data
area is not possible.  |
Schema Constants
There are some product owned schemas where the design warrants a value to be defaulted in the schema, but where the value is implementation specific and therefore cannot be defined by the product. For these situations, the product may use a technique called a schema constant. The design of the schema will include a declared constant. At implementation time, a configuration task will include defining the appropriate value for the constant.
For example, imagine the product delivers an algorithm that will create an outbound message when a certain condition occurs. The outbound message type to use must be configured by the implementation. To use a schema constant to define the outbound message type, the base product will configure the following:
An option type lookup value for the lookup F1CN_OPT_TYP_FLG is defined. For example, M202 - Activity Completion Outbound Message Type with a Java Value Name of outmsgCompletion
The base schema that is used to create the "complete activity" outbound message references the schema constant using the Java Value Name of the option type's lookup value
... <outboundMessageType mapField="OUTMSG_TYPE_CD" default="%Constant(outmsgCompletion)"/> ...
At implementation time, the administrative users must configure the appropriate outbound message type for "activity completion". Then, navigate to Feature Configuration, choose the Schema Constants feature type, choose the option type Activity Completion Outbound Message Type and enter the newly created outbound message type in the option value.
Schema constants may also be used in the flattening syntax to define the row elements required for flattening.
Defaulting and System Variables
The default attribute can be used to default values into field elements as well as the row elements required for flattening . You can default a field to a constant or to one of several system variables.
When an element is required, the default value is applied at the server level when adding or changing the record where no value is provided for this element.
When an element is optional, a default value may be configured to provide a suggested value to the user when populating the record on the user interface in Add mode. Users should be able to remove the default value for this type of element and the system will not attempt to populate it at save time.
The standard for our 'list' maintenance is to show an empty row for a new list that a user may or may not choose to populate. As such, UI default values are not shown for list elements.
It is not recommended to configure a default attribute for an optional element that is not editable or visible on the user interface in Add mode (for example an element with suppress="true" or suppress="input" or a list element whose default value is not shown per the previous point). The default for this type of element is still applied but the user doesn't have the ability to reset the value. This may result in inconsistencies as defaulting does not occur for optional fields added by a use case other than the UI interaction.
| default= | "value" | Use this attribute to default an element to a specified value. The values that are valid depend on the dataType setting. |
| "%CurrentDate" | Used to default the element to the current date. This is only applicable to date elements. |
| "%CurrentDateTime" | Used to default the element to the current date / time. This is only applicable to date / time elements. |
| "%StandardDateTime" | Used to default the standard date and time.  The standard date
and time is identical to the current date and time, unless daylight
savings time / summer time is in effect for the base time zone.  This
may be used with the stdTime attribute. Note:
Refer to Standard Time Considerations for more information.  |
| "%ProcessDate" | You can default the process date. The process date differs from the current date because the process date will remain constant throughout the duration of the process being executed. The current date will reflect the actual date of processing. This is similar to the batch business date that is a standard batch parameter. |
| "%ProcessDateTime" | This is similar to "%ProcessDate" but for date / time fields. |
| "%CurrentUser" | Used to default the element to the current user. |
| "%CurrentUserTimeZone" | Used to default the element to the current user's time zone. If the current user's time zone is not found, the installation time zone is used. |
| "%CurrentUserLanguage" | Used to default the element to the current user's language. |
| "%InstallationCurrency" | Used to default the currency from the installation record. |
| "%InstallationCountry" | You can default the country from installation record. |
| "%InstallationLanguage" | You can default the language from the installation record. |
| "%Constant( )" | You can default an element value using a schema constant. | The following is an example of a schema constant used as a
default value, where the Java Value Name of the Lookup Value is 'customerLanguage'.
| "%Context( )" | You can default a value contained in a context variable. Warning:
Context variables must be initialized within a server
script before the schema context default can be applied. Refer to Context Variables for more information.  |
An example of a context variable used as a default value:
When defining a context variable
in scripting, it should be prefixed with $$. When referring to the variable
in the %Context( ) syntax,
the prefix is not included.  |
| defaultRef= | "XPath" |
 Use this attribute to default the value of one element to the value of another one.  |
 Refer to Referencing Other Elements for supported syntax for referring to other elements.  |
The Flattening Nodes and Attributes
The term "flattening" is used to describe the act of defining one or more single elements for a schema that are actually part of a list within the maintenance object. Flattening is possible if there are other attributes of the list that can be defined to uniquely describe the element or elements. A common use case for flattening is a characteristic. Rather than defining the characteristics of an object using a collection where the user must choose the characteristic type and then define the value, the characteristics are defined as actual elements with the appropriate label already displayed. This technique enables the designer of the schema and the user interface to display each separate characteristic in the logical place in the user interface rather than all lumped together.
Identifying the List or Child Table
When flattening a child table, the row node is required to identify the list / child table that the element comes from. Within the row node, at least one element must be defined with an is= definition that ensures that the element is a unique row in the database. It may also define elements or fields in the row that are suppressed and are populated using default value configuration.
For a business object, the row node defines the child table the flattened field belongs to.
The syntax is <row mapChild="table name">. This example is for the list of persons for an account in the customer care and billing product. One person may be marked as the "main" person. This illustrates how to define an explicit element for the main person ID to simplify references to that field. It is part of the CI_ACCT_PER child table. What makes it unique is that the MAIN_CUST_SW is true (and only one row may have that value)
<custId mapField="PER_ID" mdField="CM-MainCust"> <row mapChild="CI_ACCT_PER"> <MAIN_CUST_SW is="true" /> <ACCT_REL_TYPE_CD default="MAIN" /> </row> </custId>Note:The above example illustrates that the row node may also define elements within the list that are suppressed and assigned a default value. This syntax is never used to identify a particular row. Note that a default value can either be a literal string, or a system variable. -
For a business service, the row node identifies the list name the flattened field belongs to.
The syntax is <row mapList="list name">. This example shows two entries from a list being flattened to a field value and description.
<selectList type="list" mapList="DE"> <value mapField="COL_VALUE"> <row mapList="DE_VAL"> <SEQNO is="2"/> </row> </value> <description mapField="COL_VALUE"> <row mapList="DE_VAL"> <SEQNO is="3"/> </row> </description> </selectList>
Uniquely Identifying the Flattened Field or List
The is= syntax within a row or rowFilter element is used to uniquely identify the row.
| is= | "value" | Use this attribute to reference a value directly. |
| "%Constant( )" | You can configure a flattened element using a schema constant. During a service interaction the value of the schema constant will be used to identify the flattened element in its child row. |
 An example of a schema constant used in flattening syntax where the Java Value Name of the Lookup field value is 'cmRate'.
| "%n" | The %n substitution value is used to reference a relative list instance. A relative list instance is typically used to configure a flattened element for a child table keyed by sequence number. The value of n should be a positive integer value. During a business object read interaction the relative list instance (position) specified by the integer will be returned. | An example with a relative list instance - where the first instance of the row is returned.
Flattening a Pre-defined Characteristic Type
If the flattened field is in a characteristic collection and the characteristic type is a predefined characteristic, automatic UI rendering will generate a dropdown for the list of valid values. For example, the schema below will generate a dropdown for the Usage element showing the valid values of the Status Reason Usage (F1-SRUSG) characteristic type.
<usage mdField="STATUS_RSN_USAGE" mapField="CHAR_VAL">
  <row mapChild="F1_BUS_OBJ_STATUS_RSN_CHAR">
      <CHAR_TYPE_CD is="F1-SRUSG"/>
      <SEQ_NUM is="1"/>
  </row>
</usage>
Defining Multiple Elements from the List
When attempting to include multiple columns from the same list, the system provide shorthand notation for copying the flattening rules defined on another element so that the flattening rules do not need to be repeated. To do this, the row node includes the rowRef attribute and it indicates the other element name that defines the mapping information. The following example illustrates flattening the fields Customer ID and Receives Copy of Bill from the same list of Persons for an Account (where the MAIN_CUST_SW is true ).
<custId mapField="PER_ID">
  </row>
</custId>
<copyBill mapField="RECEIVE_COPY_SW" rowRef="custId"/>
Note that the above notation also illustrates that the rowRef may be defined directly in the element's attribute definition.
Flattening Two Layers Deep
If your maintenance object or service has nested lists two layers deep, the system supports flattening an element within a flattened element. This technique also uses the rowRef attribute. The flattening of the second level refers to the flattened element of the first level. The following example illustrates flattening a characteristic into an element called legalContact for the "main" customer. Notice that the legalContact element has two row nodes: one to refer to the flattening information for its parent record and one to define its child table
  </row>
</custId>
<legalContact mapField="CHAR_VAL_FK1">
  <row rowRef="custId">
    <row mapChild="CI_ACCT_PER_CHAR" >
       <CHAR_TYPE_CD is="LEGAL" />
    </row>
  </row>
</legalContact>
Note that the above notation also illustrates that the rowRef may be defined as an attribute of a row node rather than directly in the element's attribute definition.
Defining a Flattened List
There are times that a list or child table supports multiple values of the same "type" and these should be presented as a list. To continue with the example above, the list of persons for an account may identify one person as the "main" person. This person has been flattened to a single element (with the account relationship type defaulted and suppressed). To maintain the other persons related to an account, you can define a list where each row captures the Person Id and the Account Relationship Type.
Rather than a row node, the flattened list is configured with a rowFilter element. The following schema illustrates the described example. The list node defines the child table. The rowFilter includes the criteria that identify the rows within the table to include. The elements of the list are defined within the list node outside the rowFilter element.
  </row>
</custId>
<miscPersons type="list" mapChild="CI_ACCT_PER">
  <rowFilter>
    <MAIN_CUST_SW is="false" />
  </rowFilter>
  <relType mapField="ACCT_REL_TYPE_CD"/>
  <personId mapField="PER_ID"/>
</custId>
Note that the system will validate that if a schema contains flattened single elements and flattened lists from the same child table, the criteria that defines what makes them unique must be analogous.
Flattening an Effective Dated List
There are some lists in the application that are effective dated (and still others that have effective date and time). For example, there are some effective dated characteristic collections. In these collections, the design is to capture a single value for a characteristic type that may change over time. It is not meant to support multiple characteristic values in effect at the same time.
There are some maintenance objects that have effective dated characteristics and no sequence based characteristics. For those entities, implementations may want to use the characteristic to define an additional field that doesn't require effective dates.
When considering designing an element for your schema that represents a value in an effective dated collection, consider if the value is one that is used in processes, like calculating a bill, such that it is important to capture changes to the value over time.
- If it is not important to track the changes to the value, the recommendation is to set the effective date to a fixed value in the schema. (Examples below).
 - If it is important to track the changes to the value, then you need to consider how you
want to design the schema.
- One option is to define a flattened list as described above. Both the value and the effective date are elements in this list. In this use case, you manage the list just like any list. You can add or remove values.
 - Another option is to define a flattened single value in the schema. With this option, when retrieving the record, the latest effective value is returned. In this design, the important question is how is the reference date defined.
Flattened Elements Where Changes Are Not Tracked
The following is an example of flattening an element in an effective dated collection where the value does not need to be effective dated. The recommendation in this case is to simply hard-code the date in the is= attribute.
<schema>
  <externalReference mapField="ADHOC_CHAR_VAL" mdField="CM_EXT_REF" dataType="string">
    <row mapChild="CI_SA_CHAR">
      <CHAR_TYPE is="CM_EXT_REF"/>
      <EFFDT is="2000-01-01"/>
    </row>
  </externalReference>
</schema>
Flattened Elements Where Changes Are Effective Dated
If you want the BO schema to flatten an effective dated value that should keep track of changes over time, the flattened value will represent the latest effective entry. In this case, the recommendation is to explicitly define the date or date/time field as an element. Then there is syntax for the is= attribute to indicate that the explicit date field is the date to use for the value.
| is= | "%effectiveDate( )" | Use this configuration to indicate that the date to use is the value of another element.
| "%effectiveDateTime( )" | Use this configuration to indicate that the date / time to use is the value of another
element.  Note:
elements.   |
You should consider if the explicit date or date/time element should be displayed on the user interface when the flattened field is shown or if that should be suppressed. Designers should also consider the user dialogue for updating the value. It may be more intuitive for the flattened field to be display only and to have a separate dialogue for updating the effective dated value.
For this option, the suggestion is that the maintenance page for the object includes a separate zone that shows the history of the effective dated values over time. The latest value may be included in that zone as well.
Note that for backward compatibility, the system also supports the following options. However, they are not recommended. They implicitly defined the reference date as the current date at all times. The options supported adding new effective dated rows when the value changed. But the technique also caused new effective dated rows to appear when other elements of the same schema were updated. The new rows would have the current date or date/time with the same row value because the reference date or date/time is the current date, which is a change. The product does not recommend managing an effective dated characteristic without defining the date or date/time as an explicit element.
| is= | "%effectiveDate" |
 This configuration is not recommended  |
| "%effectiveDateTime" |
Search Zone
A UI Map schema element can be configured to enable an automatic search dialog when the schema is included within a maintenance UI map.
search="search zone"
The search attribute can be used within a UI map schema and is used to automatically generate the oraSearch UI map attribute. The search zone is an explorer zone configured as a search.
<person fkRef="PER" search="C1_PSRCH"/>
searchField="search field:element|'literal';"
The searchField attribute can only be used in conjunction with the search attribute. The searchField attribute is used to build the oraSearchField UI map attribute. The searchField value is used to populate a search zone filter with an initial value when the search zone is launched. The initial value can be a literal also. The searchField value is used to match to the filter mnemonic also named searchField.
Search field: element|'literal'. The search field represents the search zone filter to populate on launch. The element is the map's schema element used to populate the filter. The element is optional, if left blank, it will default to the element that this attribute is specified on. The searchField also takes 'literal' as input value
<person fkRef="PER" search="C1_PSRCH" searchField="PERSON; PER_TYPE:personType;"/>
searchOut="search field:element;"
The searchOut attribute can only be used in conjunction with the search attribute. The searchOut attribute is used to build the oraSearchOut UI map attribute. The searchOut value is used to capture a selected value from the search zone and move it to a UI map element. The searchOut value specified should match the ELEMENT_NAME mnemonic within the search result zone parameter.
Search field: element. The search field represents the search zone result brought back to the UI map. The element is the map's schema element to be populated. The element is optional, if left blank, it will default to the element that this attribute is specified on.
<person fkRef="PER" search="C1_PSRCH" searchField="PER_ID"
searchOut="PER_ID;PRIMARY_PHONE:personPhone;"/>
Extend Security for Service Script
Application service security will be enforced when either a business object or a service script is invoked from a BPA script or a UI map, but not from a service script. If you want security to be enforced when the business object or a service script is invoked from a service script, you must add the following attribute to the service script's schema.
appSecurity="true"
The appSecurity attribute is only available for service script schemas. If specified, any business object or service script directly invoked by the service script will have their application service evaluated for access.
<schema appSecurity="true">
</schema>
Overriding Action for a Business Service
If you want to invoke a business service with an action other than 'read', you need to specify the action attribute on the primary node business service schema.
pageAction="add, change, delete"
The action attribute is used to override the default action of read on a business service schema. Valid values are:
add
update (only allowed for maintenance object service)
change (not allowed for maintenance object service)
delete
read (this is the default action if no pageAction specified)
Example:
<schema pageAction="change">
  <parm type="group">
    <ele1/>
    <ele2/>
  </parm>
</schema>
Specifying searchBy for a Search Service
If you want to invoke a search service then you must explicitly specify the searchBy attribute appropriate for the elements mapped in the schema.
searchBy="MAIN"
The value values of the searchBy attribute can be found by viewing the XML schema linked to the business service, use the View XML URL. Typical values are:
MAIN
ALT
ALT2
ALT3
 - etc.
<schema searchBy="MAIN">
  <AccountID mapField="ACCT_ID"/>
  <Results type="list">
  </Results>
</schema>
Including Other Schemas
There are no limitations on your ability to include a schema into another schema - all types can be included in all other types. Nested includes are also allowed - and at present there is no limitation on the depth of the nesting.
Including a schema requires two parts:
- The include node
 - The name attribute
The following table highlights the supported include statements.
| Mnemonic | Description | Examples |
 <includeBO name=" "/>  |
 Including a business object schema into another schema is allowed. Note that the mapping rules of a business object or business service schema may or may not make sense in the context of the parent schema. Include other schemas at your own risk. However, a very useful aspect of XML processing is that the framework ignores non-pertinent attributes. In other words, it will not hurt to have mapping attributes included into a script schema.  |
 <includeBS name=" "/>  |
 Used to include a business service schema.  |
 <includeDA name=" "/>  |
 Used to include a data area schema.  |
 <includeMP name=" "/>  |
 Used to include a UI map schema.  |
 <includeSS name=" "/>  |
 Used to include a service script schema.  |
Compatibility Attributes
These attributes were added as part of upgrades from previous versions of the Framework.
fwRel="2"
This attribute has been added to schemas created in Framework 2 as part of a Framework 4 upgrade. New schemas will not need this attribute. It is not advisable to modify this attribute without understanding the following behavior differences as improper changes could result in errors:
<schema fwRel="2"
</schema>
