Upgrade Procedure
The upgrade installation procedure consists of:
Database Component Upgrade
Upgrade of the database component of Oracle Utilities Meter Data Management must be complete before you can proceed with the following sections. Refer to the Upgrade Install section in the Oracle Utilities Meter Data Management Database Administrator’s Guide for instructions to upgrade the database component.
Application Components Upgrade
A successful upgrade consists of the following steps:
Upgrading the Oracle Utilities Application Framework V4.5.0.0.0 Application Component
This section describes how to upgrade the application component of Oracle Utilities Application Framework, including:
Copying and Decompressing Install Media
The Oracle Utilities Application Framework V4.5.0.0.0 installation file is delivered in jar format for both UNIX and Windows platforms. If you are planning to install multiple Oracle Utilities Application Framework environments operated by different Oracle Utilities administrator user IDs, you must complete each of the following installation steps for each administrator userid.
To copy and decompress the install media:
1. Login to the application server host with the Oracle Utilities Application Framework administrator user ID.
2. Download the Oracle Utilities Application Framework V4.5.0.0.0 Multiplatform from Oracle Software Delivery Cloud.
3. Create a temporary directory such as c:\ouaf\temp or /ouaf/temp. (Referred to below as <TEMPDIR>.)
Note: This directory must be located outside any current or other working Oracle Utilities application environment. All files that are placed in this directory as a part of the installation can be deleted after completing a successful installation.
4. Copy the file FW-V4.5.0.0.0-MultiPlatform.jar from the delivered package to the <TEMPDIR>. Make sure to use the BINARY option to use FTP to transfer this file.
5. Decompress the file.
cd <TEMPDIR>
jar -xvf FW-V4.5.0.0.0-MultiPlatform.jar
Note: In order to be able to execute the “jar” command you need to have the Java JDK installed.
A sub-directory named FW-V4.5.0.0.0 is created. It contains the installation software for the Oracle Utilities Framework Application server.
Setting Permissions for the cistab file in UNIX
Every Oracle Utilities Application Framework environment installed on a server must be registered in the /etc/cistab file located on that server. On UNIX servers, generally only the root user ID has write permissions to the /etc directory. Since the installation process is run by the Oracle administrator user ID (cissys), this user ID may not be able to write to /etc/cistab table.
The install utility checks permissions and if it identifies a lack of the necessary permissions, it generates a script in the <TEMPDIR>/App/FW.V4.5.0.0.0 directory named cistab_<SPLENVIRON>.sh. Run the generated script using the root account before continuing with the installation process. The script initializes the cistab file in /etc directory (if it is the first Oracle Utilities Framework application environment on the server) and registers a new environment.
The generated script also changes the owner of /etc/cistab file to the Oracle Utilities Framework administrator user ID, so that the next time a new environment is created by the same Oracle Utilities Framework administrator user ID, you do not need to run the generated script with the root user ID. Instead the install utility itself proceeds with the registration.
If you are reinstalling an existing environment, only the validation of /etc/cistab entry is done by the install utility, no new registration occurs. The install utility interactively instructs you about every step that needs to occur in each specific case.
If you are planning to upgrade an existing environment it is your responsibility to take a backup prior to the upgrade process. The installation utility does not create a backup of existing environment.
Upgrading the Application Component
This section outlines the steps to install the application component of Oracle Utilities Application Framework V4.5.0.0.0.
Note: If your Oracle Utilities Meter Data Management version installed is prior to 2.2.0.2.0, you must install V2.2.0.2.0 before upgrading to V2.5.0.0.0.
If you have Oracle Utilities Meter Data Management v2.3.0.0.0 installed, you must install v2.3.0.2.0 before upgrading to v2.5.0.0.0.
1. Login to the Application Server host as administrator (the default is cissys on UNIX) or as a user with Administrator privileges (on Windows).
2. Change directory to the bin folder.
cd <install_dir>/bin
where <install_dir> is the location where the Oracle Utilities Application Framework Base application component is installed.
3. Initialize the environment by running the appropriate command:
UNIX
./splenviron.sh -e <ENV NAME>
Windows
splenviron.cmd -e <ENV NAME>
4. Change directory to <TEMPDIR>/App/FW.V4.5.0.0.0.
Note: While installing the FW V4.5.0.0.0 from the previous environment to V2.5.0.0.0, the install utility removes the existing environment and re-creates the environment. Take a backup before you proceed with installing FW V4.5.0.0.0 to retain any configurations for future reference.
5. Start the application installation utility by executing the appropriate script:
UNIX:
ksh ./install.sh -u
Windows:
install.cmd
The Oracle Utilities Application Framework specific menu appears.
6. Follow the messages and instructions that are produced by the application installation utility.
8. The following is the mandatory list of configurable items with descriptions for a few items. Where you see <Mandatory>, enter values suitable to your environment. You can assign default values to the rest of the menu items.
* Environment Installation Options *
1. Environment ID, Roles, Third Party Software Configuration
Environment ID | <Default> |
Server Roles | batch, online |
Oracle Client Home Directory | <Mandatory for Initial Install> |
Web Java Home Directory | <Mandatory for Initial Install> |
Hibernate JAR Directory | <Mandatory for Initial Install> |
ONS JAR Directory | <Optional> |
Web Application Server Home Directory | <Mandatory for Initial Install> |
Additional JAR Directory | <Optional> |
2. Keystore Options
Import Keystore Directory | <Default> |
50. Environment Installation Options
Environment Mount Point | <Mandatory> |
Log Files Mount Point | <Mandatory> |
Environment Name | <Mandatory> |
Install Application Viewer Module | true |
Install Sample CM Source Code | true |
Each item in the above list should be configured for a successful install.
Choose option (1,2,50, <P> Process, <X> Exit):
Once you enter 'P' after entering mandatory input values in the above menu, the system populates another configuration menu.
* Environment Configuration *
1. Environment Description
Environment Description | <Mandatory> |
2. Business Application Server Configuration
Business Server Host | <Mandatory> - Hostname on which application being installed |
Business Server Application Name | SPLService |
3. Web Application Server Configuration
Web Server Host | <Mandatory> |
WebLogic SSL Port Number | <Mandatory> |
WebLogic Console Port Number | <Mandatory> |
Web Context Root | ouaf |
WebLogic JNDI User ID | <Mandatory> |
WebLogic JNDI Password | <Mandatory> |
WebLogic Server Name | myserver |
Web Server Application Name | SPLWeb |
Deploy Application Viewer Module | true |
Enable The Unsecured Health Check Service | false |
MDB RunAs User ID | <Mandatory> |
Super User IDs | <Mandatory> |
4. Database Configuration
Application Server Database User ID | <Mandatory> |
Application Server Database Password | <Mandatory> |
XAI Database User ID | <Mandatory> |
XAI Database Password | <Mandatory> |
Batch Database User ID | <Mandatory> |
Batch Database Password | <Mandatory> |
Web JDBC DataSource Name | <Optional> |
Database Name | <Mandatory> |
Database Server | <Mandatory> |
Database Port | <Mandatory> |
ONS Server Configuration | <Optional> |
Database Override Connection String | <Optional> |
Character Based Database | false |
Oracle Client Character Set NLS_LANG | AMERICAN_AMERICA.AL32UTF8 |
5. General Configuration Options
Batch RMI Port | <mandatory> |
RMI Port number for JMX Business | <optional> |
RMI Port number for JMX Web | <optional> |
JMX Enablement System User ID | <optional> |
JMX Enablement System Password | <optional> |
Coherence Cluster Name | <mandatory> |
Coherence Cluster Address | <mandatory> |
Coherence Cluster Port | <Mandatory> |
Coherence Cluster Mode | prod<Mandatory> |
6. OUAF TrustStore Options
Import TrustStore Directory | <Mandatory> for Prod |
Choose option (1,2,3,4,5,6 <P> Process, <X> Exit):
9. When the parameter setup is complete, proceed with the option P. The utility writes the configured parameters and their values into the configuration file.
10. Once the install or upgrade has finished, the installation log location is displayed on the screen. If the log does not list any error messages, the installation of the application component of Oracle Utilities Application Framework is complete.
You can now install Oracle Utilities Meter Data Management as described in the following section.
Upgrading the Oracle Utilities Meter Data Management Application Component to V2.5.0.0.0
This section describes how to install the application component of Oracle Utilities Meter Data Management, including:
The Oracle Utilities Meter Data Management installation file is delivered in jar format for both UNIX and Windows platforms.
2. Download the Oracle Utilities Meter Data Management V2.5.0.0.0 Multiplatform.zip from Oracle Software Delivery Cloud.
3. Create a temporary directory such as c:\ouaf\temp or /ouaf/temp. (Referred to below as <TEMPDIR>)
4. Unzip Oracle Utilities Meter Data Management V2.5.0.0.0 Multiplatform.zip to get the file MDM_V2.5.0.0.0.zip from the delivered package and copy to the <TEMPDIR>. If you are using FTP to transfer this file, remember to use the BINARY option for the FTP transfer.
cd <TEMPDIR>
unzip MDM_V2.5.0.0.0.zip
cd App
To install Oracle Utilities Meter Data Management application component:
1. Login to the application server host as Oracle Utilities Meter Data Management Administrator (default cissys).
2. Change directory.
where <install_dir> is the location where the Oracle Utilities Application Framework application component is installed.
3. Initialize the environment by running the appropriate command.
UNIX
Windows
4. Run the install script.
Note: On UNIX, make sure that you have the proper execute permissions on install.sh.
UNIX
ksh ./install.sh -u
Windows
install.cmd
5. Select menu item 8 to configure OSB.
6. Select menu item 9 to configure SOA.
7. Select menu item 10 to configure the SOA Configuration Plan.
When you are done with the parameter setup, choose option P to proceed with the installation.
Note: Rest of the menu items can be ignored if you are installing only Oracle Utilities Meter Data Management.
Installation of Oracle Utilities Meter Data Management Application Server is complete if no errors occurred during installation.
8. Generate the appviewer.
a. Change the directory.
where <install_dir> is the Oracle Utilities Meter Data Management application component installation directory.
b. Run the script to generate the appviewer.
UNIX
ksh ./genappvieweritems.sh
Windows
genappvieweritems.cmd
Creating WebLogic Domain
Create the WebLogic native domain and deploy the application. For instructions refer to the Native Installation Oracle Utilities Application Framework (Doc ID: 1544969.1) white paper on My Oracle Support.
The MDB user configured in Menu 3 during the Oracle Utilities Application Framework installation has to be created in the Oracle Utilities Application Framework application and WebLogic console, and should be part of the “cisusers” group.
Note: When starting Oracle Utilities Meter Data Management for the first time, login to the WebLogic console and provide system access to the cisusers role. Use the following URL to access the WebLogic console application: http://<hostname>:<portname>/ console.
After the Upgrade
After you complete the upgrade installation, verify the following:
1. Verify installation logs created under decompressed installer location for any errors.
2. Confirm installation logs do not contain any errors.
4. Confirm that the database is ready.
