Software Directory Structure
The following components are stored in the base code directory structure:
• Runtimes for Components – All the runtime executables for the base software.
• Business Object Binaries – All the binaries that contain the business logic.
• Configuration Files – All the configuration files for the business objects and runtimes.
• Scripts – Any administration or runtime scripts that are supplied to the customer.
• Supported Plug-ins – Source and executable for supplied plug-ins.
The following table outlines the typical contents of these directories:
Directory
Contents
bin
Utilities and commands for operations and configuration.
etc
A set of directories holding configuration files used in Oracle Utilities Meter Data Management as well as template files and base libraries used to generate the configuration files.
java
Location of temporary files for Java execution.
ks
Location of Key Stores.
oem
Application Management Suite for Oracle Utilities generated files.
Note: Files in this directory are generated by the discovery process used with the Oracle Application Management Pack for Oracle Utilities.
logs
Location of Oracle Utilities Meter Data Management specific log files.
osbapp
Oracle Service Bus integration (optional).
product
Directories containing any bundled software with the product.
scripts
Directory containing any implementation specific scripts.
soaapp
Oracle SOA integration (optional).
splapp
Directories containing the JEE web applications (see Software (splapp) Directory).
structures
Internal structures used for configuration utilities.
templates
Base templates used to build configuration files.
tmp
Directory used to hold intermediary files used for the deployment process.
tools
Location of service pack, single fix and group fix utilities (see Tools Directory).
updates
Location of installed_fixes.txt
Note: The updates directory only exists after at least one patch has been installed. If the directory does not exist, then no patches have been installed on this environment.
Under the splapp subdirectory for each environment there are several subdirectories:
Directory
Contents
applications
Location of the web application product files.
billView
Location of the online bill viewing files (products supporting bill view only).
businessapp
Location of the business application product files.
certs
Location of security certificates.
config
Location of temporary configuration files.
iws
Location of native web services.
ohelpsource
Oracle Help engine source location.
pending
Internal use only.
standalone
Location of common Java libraries and the batch component of the product.
tpw
Location of threadpool worker specific files.
xmlMetaInfo
Location of the service definitions for the product.
Warning: Under no circumstances should files be manually altered in these directories unless instructed by Oracle Support. The Oracle Utilities SDK will deposit files in the relevant locations in this structure using the Packaging component of the SDK or using the Development tools directly.
Tools Directory
Note: In past releases the utilities to install patches were included in each patch. This is not the case anymore as they are centralized as part of the installation.
Note: These utilities are not usually executed manually but are part of general installations and automation from Application Management Pack for Oracle Utilities
The tools directory is used for deployment and patching tools used by Application Management Pack for Oracle Utilities and the internal patching utilities. The directories are in the following structure:
Directory
Contents
bin
General Software patching utilities.
bin/db
Database Patching utilities.
bin/db/bin
Binaries for patching.
bin/db/config
Logging configuration for patching utilities.
bin/db/lib
Java Libraries for patching utilities.
domaintemplates
Oracle WebLogic Domain Templates for product.
Directory Permissions
The directories within Oracle Utilities Meter Data Management are controlled by the operating system security relating to the administration user assigned to the product. The table below outlines the permissions under the $SPLEBASE location:
Directory/files
Owner
Group
Other
etc
rwx
r-x
Individual files
rw-
r--
logs
rwx
rwx
logs/system
rwx
rwx
Individual log files
rw-
r--
Oracle WebLogic Configuration Files
rw-
r--
Oracle WebLogic shell scripts (.sh)
rwx
r-x
product
rwx
r-x
product/apache-ant/bin/ant
rwx
r-x
scripts, tools, updates
rwx
r-x
Shell scripts (.sh) in bin
rwx
r-x
osbapp, soaapp, splapp
rwx
r-x
structures
rwx
r-x
templates
rwx
r-x
tmp
rwx
r-x
Legend:
• r – Read Only
• rw – Read Write
• rwx – Read/Write/Execute
• rx – Read/Execute
• blank – no permissions.
These permissions are set by the setpermissions.sh utility which is executed as outlined in the Installation Guide.
