Understanding Command Sets
Command sets are used to define a group of commands that are not eligible for a particular device. For instance, if Commission or Decommission commands should be considered ineligible for a particular device model, a command set that references the Device Commission and Device Commission business objects could be created and associated with that device model.
Command sets are specified for individual device models via the Manufacturer portal.
Individual devices of a particular model can be configured to override ineligibility if needed.
