Table Name | Table Partitioning Type (Partitioning, Sub-Partitioning Key) | Index Name | Index Columns | Index Type (Global or Local) | Index Partitioning (Sub-Partitioning Key) | ILM_DT (Initial Load) |
F1_STATS_ SNPSHT(Parent) | RANGE (ILM_DT, SNAPSHOT_ID) | RANGE (SNAPSHOT_ID) | F1_STATS_ SNPSHT. CRE_DTTM | |||
Reference Partitioning | F1C706P0 | SNAPSHOT_ID | Global Partitioned | |||
F1C706S1 | BUS_OBJ_CD,BO_STATUS_CD,SNAPSHOT_ID | Global | ||||
CM_ILM_F1C706L0 | ILM_DT,ILM_ARCH_SW | Local | ||||
F1_STATS_SNPSHT_CHAR | Reference Partitioning | F1C707P0 | SNAPSHOT_ID,CHAR_TYPE_CD,SEQ_NUM | Global Partitioned | ||
F1C707S1 | SRCH_CHAR_VAL | Global | ||||
F1_STATS_SNPSHT_LOG | Reference Partitioning | F1C708P0 | SNAPSHOT_ID,SEQNO | Global Partitioned | ||
F1C708S1 | CHAR_TYPE_CD,CHAR_VAL_FK1 | Global | ||||
F1C708S2 | CHAR_TYPE_CD,CHAR_VAL | Global | ||||
F1_STATS_SNPSHT_LOG_PARM | Reference Partitioning | F1C709P0 | SNAPSHOT_ID,SEQNO,PARM_SEQ | Global Partitioned | ||
F1_STATS_SNPSHT_REL_OBJ | Reference Partitioning | F1C710P0 | SNAPSHOT_ID,STATS_SNPSHT_REL_OBJ_TYPE_FLG,SEQ_NUM | Global Partitioned |
Table Name | Table Partitioning Type (Partitioning, Sub-Partitioning Key) | Index Name | Index Columns | Index Type Global or Local | Index Partitioning Sub-Partitioning Key | ILM_DT Initial Load |
D1_ACTIVITY (Parent) | RANGE (ILM_DT, D1_ACTIVITY_ID) Note: Default is to use sub-retention or use RANGE (ILM_DT, D1_ACTIVITY_ID) if not using sub-retention. | D1_ACTIVITY. CRE_DTTM | ||||
D1T319P0 | D1_ACTIVITY_ID | Global Partitioned | RANGE (D1_ACTIVITY_ID) | |||
D1T319S0 | BUS_OBJ_CD, BO_STATUS_CD, D1_ACTIVITY_ID | Global Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_ACTIVITY_ID) | |||
CM_ILM_D1T319S1 | ILM_DT, ILM_ARCH_SW, D1_ACTIVITY_ID | Local | ||||
D1_ACTIVITY_CHAR | REFERENCE (D1_ACTIVITY_CHAR_FK) | |||||
D1T320P0 | D1_ACTIVITY_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1T320S0 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_ACTIVITY_ IDENTIFIER | REFERENCE (D1_ACTIVITY_IDENTIFIER_FK) | |||||
D1T330P0 | D1_ACTIVITY_ID, ACTIVITY_ID_TYPE_ FLG | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1T330S0 | ACTIVITY_ID_TYPE_ FLG, ID_VALUE | Global Partitioned | HASH(ACTIVITY_ ID_TYPE_FLG, ID_VALUE) | |||
D1T330S1 | ACTIVITY_ID_TYPE_FLG, UPPER(ID_VALUE) | Global | ||||
D1_ACTIVITY_LOG | REFERENCE (D1_ACTIVITY_ LOG_FK) | |||||
D1T321P0 | D1_ACTIVITY_ID, SEQNO | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1T321S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global Partitioned | HASH(CHAR_TYPE_CD, CHAR_VAL_FK1) | |||
D1T321S2 | CHAR_TYPE_CD, CHAR_VAL | Global Partitioned | HASH(CHAR_TYPE_CD, CHAR_VAL) | |||
D1_ACTIVITY_LOG_ PARM | REFERENCE (D1_ACTIVITY_LOG_PARM_FK) | |||||
D1T322P0 | D1_ACTIVITY_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1_ACTIVITY_REL | REFERENCE (D1_ACTIVITY_REL_FK) | |||||
D1T323P0 | D1_ACTIVITY_ID, ACTIVITY_REL_TYPE_ FLG | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1T323S0 | REL_ACTIVITY_ID | Global Partitioned | HASH(REL_ ACTIVITY_ID) | |||
D1_ACTIVITY_REL_OBJ | REFERENCE (D1_ACTIVITY_REL_OBJ_ FK) | |||||
D1T324P0 | D1_ACTIVITY_ID, MAINT_OBJ_CD, ACTIVITY_REL_OBJ_TYPE_FLG | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1T324S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global Partitioned | HASH(PK_VALUE1,PK_VALUE2, PK_VALUE3, PK_VALUE4) |
D1_COMM_IN (Parent) | RANGE(ILM_DT, D1_COMM_ID) | D1_COMM_IN. CRE_DTTM | ||||
D1T386P0 | D1_COMM_ID | Global Partitioned | RANGE (D1_COMM_ID) | |||
D1T386S1 | BUS_OBJ_CD, BO_STATUS_CD, D1_COMM_ID | Global Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_COMM_ID) | |||
CM_ILM_D1T386S1 | ILM_DT, ILM_ARCH_SW, D1_COMM_ID | Local | ||||
D1_COMM_IN_CHAR | REFERENCE (D1_COMM_IN_CHAR_FK) | |||||
D1T387P0 | D1_COMM_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE (D1_COMM_ID) | |||
D1T387S0 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_COMM_IN_ IDENTIFIER | REFERENCE (D1_COMM_IN_ IDENTIFIER_FK) | |||||
D1T391P0 | D1_COMM_ID, COMM_ID_TYPE_FLG | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1T391S0 | COMM_ID_TYPE_FLG, ID_VALUE | Global Partitioned | HASH(COMM_ID_TYPE_FLG, ID_VALUE) | |||
D1T391S1 | COMM_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
D1_COMM_IN_LOG | REFERENCE (D1_COMM_IN_LOG_FK) | |||||
D1T388P0 | D1_COMM_ID, SEQNO | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1T388S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
D1T388S2 | CHAR_TYPE_CD, CHAR_VAL | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
D1_COMM_IN_LOG_ PARM | REFERENCE (D1_COMM_IN_LOG_PARM_FK) | |||||
D1T389P0 | D1_COMM_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1_COMM_IN_REL_OBJ | REFERENCE (D1_COMM_IN_REL_OBJ_ FK) | |||||
D1T390P0 | D1_COMM_ID, MAINT_OBJ_CD, COMM_REL_OBJ_TYPE_FLG | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1T390S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
D1_COMM_OUT (Parent) | RANGE(ILM_DT,D1_COMM_ID) | D1_COMM_ OUT. CRE_DTTM | ||||
D1T380P0 | D1_COMM_ID | Global Partitioned | RANGE (D1_COMM_ID) | |||
D1T380S1 | BUS_OBJ_CD, BO_STATUS_CD, D1_COMM_ID | Global Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_COMM_ID) | |||
CM_ILM_D1T380S1 | ILM_DT, ILM_ARCH_SW, D1_COMM_ID | Local | ||||
D1_COMM_OUT_CHAR | REFERENCE (D1_COMM_OUT_CHAR_FK) | |||||
D1T381P0 | D1_COMM_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE (D1_COMM_ID) | |||
D1T381S0 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_COMM_OUT_IDENTIFIER | REFERENCE (D1_COMM_OUT_IDENTIFIER_ FK) | |||||
D1T385P0 | D1_COMM_ID, COMM_ID_TYPE_FLG | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1T385S0 | COMM_ID_TYPE_FLG, ID_VALUE | Global Partitioned | HASH(COMM_ID_TYPE_FLG, ID_VALUE) | |||
D1T385S1 | COMM_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
D1_COMM_ OUT_LOG | REFERENCE (D1_COMM_OUT_LOG_FK) | |||||
D1T382P0 | D1_COMM_ID, SEQNO | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1T382S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
D1T382S2 | CHAR_TYPE_CD, CHAR_VAL | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
D1_COMM_OUT_LOG_PARM | REFERENCE (D1_COMM_OUT_LOG_PARM_FK) | |||||
D1T383P0 | D1_COMM_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1_COMM_OUT_REL_OBJ | REFERENCE (D1_COMM_OUT_REL_OBJ_FK) | |||||
D1T384P0 | D1_COMM_ID, MAINT_OBJ_CD, COMM_REL_OBJ_TYPE_FLG | Global Partitioned | RANGE(D1_COMM_ID) | |||
D1T384S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
D1_DVC_EVT (Parent) | RANGE(ILM_DT, DVC_EVT_ID) Note: Default is to use sub-retention or use RANGE (ILM_DT,DVC_EVT_ID) if not using sub-retention. | D1_DVC_EVT. CRE_DTTM | ||||
D1T400P0 | DVC_EVT_ID | Global Partitioned | RANGE (DVC_EVT_ID) | |||
D1T400S1 | BUS_OBJ_CD, BO_STATUS_CD, DVC_EVT_ID | Global Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, DVC_EVT_ID) | |||
D1T400S2 | D1_DEVICE_ID, DVC_EVT_DTTM | Global Partitioned | HASH(D1_DEVICE_ID, DVC_EVT_DTTM) | |||
D1T400S3 | BUS_OBJ_CD, BO_STATUS_CD, D1_DEVICE_ID, DVC_EVT_ID | Global Partitioned | HASH(BUS_OBJ_CD, BO_STATUS_CD, D1_DEVICE_ID, DVC_EVT_ID) | |||
CM_ILM_D1T400S4 | ILM_DT, ILM_ARCH_SW, DVC_EVT_ID | Local | ||||
D1_DVC_EVT_CHAR | REFERENCE (D1_DVC_EVT_ CHAR_FK) | |||||
D1T401P0 | DVC_EVT_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE(DVC_EVT_ID) | |||
D1T401S0 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_DVC_EVT_ IDENTIFIER | REFERENCE (D1_DVC_EVT_ IDENTIFIER_FK) | |||||
D1T405P0 | DVC_EVT_ID, DVC_EVT_ID_TYPE_FLG | Global Partitioned | RANGE(DVC_EVT_ID) | |||
D1T405S0 | DVC_EVT_ID_TYPE_FLG, ID_VALUE | Global Partitioned | HASH(DVC_EVT_ID_TYPE_FLG, ID_VALUE) | |||
D1T405S1 | DVC_EVT_ID_TYPE_FLG, UPPER(ID_VALUE) | |||||
D1_DVC_EVT_LOG | REFERENCE (D1_DVC_EVT_LOG_FK) | |||||
D1T402P0 | DVC_EVT_ID, SEQNO | Global Partitioned | RANGE(DVC_EVT_ID) | |||
D1T402S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
D1T402S2 | CHAR_TYPE_CD, CHAR_VAL | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
D1_DVC_EVT_LOG_ PARM | REFERENCE (D1_DVC_EVT_LOG_PARM_FK) | |||||
D1T403P0 | DVC_EVT_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE(DVC_EVT_ID) | |||
D1_DVC_EVT_REL_OBJ | REFERENCE (D1_DVC_EVT_REL_OBJ_FK) | |||||
D1T404P0 | DVC_EVT_ID, MAINT_OBJ_CD, DVC_EVT_REL_OBJ_TYPE_FLG | Global Partitioned | RANGE(DVC_EVT_ID) | |||
D1T404S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
D1_COMPL_EVT (Parent) | RANGE(ILM_DT,COMPL_EVT_ID) | D1_COMPL_ EVT. CRE_DTTM | ||||
D1T340P0 | COMPL_EVT_ID | Global Partitioned | RANGE (COMPL_EVT_ID) | |||
D1T340S0 | D1_ACTIVITY_ID | Global Partitioned | HASH(D1_ ACTIVITY_ID) | |||
CM_ILM_D1T340S1 | ILM_DT, ILM_ARCH_SW, DVC_EVT_ID | Local | ||||
D1_COMPL_EVT_CHAR | REFERENCE (D1_COMPL_ EVT_CHAR_FK) | |||||
D1T341P0 | COMPL_EVT_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE(COMPL_ EVT_ID) | |||
D1T341S1 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_COMPL_EVT_LOG | REFERENCE (D1_COMPL_EVT_LOG_FK) | |||||
D1T342P0 | COMPL_EVT_ID, SEQNO | Global Partitioned | RANGE(COMPL_ EVT_ID) | |||
D1T342S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
D1T342S2 | CHAR_TYPE_CD, CHAR_VAL | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
D1_COMPL_EVT_LOG_PARM | REFERENCE (D1_COMPL_EVT_LOG_PARM_FK) | |||||
D1T343P0 | COMPL_EVT_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE(COMPL_ EVT_ID) | |||
D1_COMPL_EVT_REL_OBJ | REFERENCE (D1_COMPL_EVT_REL_OBJ_FK) | |||||
D1T344P0 | COMPL_EVT_ID, MAINT_OBJ_CD, COMPL_EVT_REL_OBJ_TYP_FLG | Global Partitioned | RANGE(COMPL_ EVT_ID) | |||
D1T344S0 | PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4, PK_VALUE5, MAINT_OBJ_CD | Global Partitioned | HASH(PK_VALUE1, PK_VALUE2, PK_VALUE3, PK_VALUE4) |
D1_INIT_MSRMT_DATA (Parent) | RANGE (ILM_DT,MEASR_COMP_ID) Note: Default is to use sub-retention or use RANGE (ILM_DT,MEASR_COMP_ID) if not using sub-retention. | D1_INIT_MSRMT_DATA. CRE_DTTM | ||||
D1T304P0 | INIT_MSRMT_DATA_ID | Global Partitioned | RANGE (INIT_MSRMT_DATA_ID) | |||
D1T304S1 | MEASR_COMP_ID, BO_STATUS_CD, BUS_OBJ_CD, D1_TO_DTTM, D1_FROM_DTTM | Global Partitioned | RANGE (MEASR_COMP_ ID) | |||
CM_ILM_D1T304S4 | ILM_DT, ILM_ARCH_SW, INIT_MSRMT_DATA_ID | Local | ||||
D1_INIT_MSRMT_DATA_CHAR | REFERENCE (D1_INIT_MSRMT_DATA_CHAR_FK) | |||||
D1T305P0 | INIT_MSRMT_DATA_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE(INIT_MSRMT_DATA_ID) | |||
D1T305S1 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_INIT_MSRMT_DATA_LOG | REFERENCE (D1_INIT_MSRMT_DATA_LOG_FK) | |||||
D1T306P0 | INIT_MSRMT_DATA_ID, SEQNO | Global Partitioned | RANGE (INIT_MSRMT_DATA_ID) | |||
D1_INIT_MSRMT_DATA_LOG_ PARM | REFERENCE (D1_INIT_MSRMT_DATA_LOG_PARM_FK) | |||||
D1T307P0 | INIT_MSRMT_DATA_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE (INIT_MSRMT_DATA_ID) |
D1_USAGE (Parent) | RANGE(ILM_DT, D1_USAGE_ID) | D1_USAGE. CRE_DTTM | ||||
D1T281P0 | D1_USAGE_ID | Global Partitioned | RANGE (D1_USAGE_ID) | |||
D1T281S0 | US_ID, START_DTTM | Global Partitioned | RANGE (US_ID) | |||
D1T281S1 | BUS_OBJ_CD, BO_STATUS_CD, D1_USAGE_ID | Global Partitioned | HASH(BUS_OBJ_ CD, BO_STATUS_CD, D1_USAGE_ID) | |||
CM_ILM_D1T281S2 | ILM_DT, ILM_ARCH_SW, D1_USAGE_ID | Local | ||||
D1T419S1 | USG_EXT_ID, D1_USAGE_ID | Global Partitioned | HASH (USG_EXT_ID) | |||
D1_USAGE_ CHAR | REFERENCE (D1_USAGE_ CHAR_FK) | |||||
D1T285P0 | D1_USAGE_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE(D1_ USAGE_ID) | |||
D1T285S1 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_USAGE_LOG | REFERENCE (D1_USAGE_LOG_FK) | |||||
D1T286P0 | D1_USAGE_ID, SEQNO | Global Partitioned | RANGE(D1_USAGE_ID) | |||
D1T286S1 | CHAR_TYPE_CD, CHAR_VAL_FK1 | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL_FK1) | |||
D1T286S2 | CHAR_TYPE_CD, CHAR_VAL | Global Partitioned | HASH(CHAR_ TYPE_CD, CHAR_VAL) | |||
D1_USAGE_LOG_PARM | REFERENCE(D1_USAGE_LOG_ PARM_FK) | |||||
D1T287P0 | D1_USAGE_ID, SEQNO PARM_SEQ | Global Partitioned | RANGE (D1_USAGE_ID) | |||
D1_USAGE_ PERIOD | REFERENCE(D1_USAGE_PERIOD_FK) | |||||
D1T283P0 | D1_USAGE_ID, PERIOD_SEQ_NUM | Global Partitioned | RANGE(D1_ USAGE_ID) | |||
D1_USAGE_ PERIOD_ITEM_DET | REFERENCE(D1_USAGE_PERIOD_ITEM_DET_FK) | |||||
D1T431P0 | D1_USAGE_ID, PERIOD_SEQ_NUM, ITEM_SEQ_NUM | Global Partitioned | RANGE(D1_USAGE_ID) | |||
D1_USAGE_ PERIOD_SQ | REFERENCE(D1_USAGE_PERIOD_SQ_FK) | |||||
D1T284P0 | D1_USAGE_ID, PERIOD_SEQ_NUM, SQ_SEQ_NUM | Global Partitioned | RANGE(D1_ USAGE_ID) | |||
D1_USAGE_PERIOD_SQ_DATA | REFERENCE(D1_USAGE_PERIOD_SQ_DATA_FK) | |||||
D1T497P0 | D1_USAGE_ID, PERIOD_SEQ_NUM, SQ_SEQ_NUM, SQ_DATA_DTTM | Global Partitioned | RANGE(D1_ USAGE_ID) | |||
D1_USAGE_REL | REFERENCE (D1_USAGE_REL_FK) | |||||
D1T316P0 | D1_USAGE_ID, USAGE_REL_TYPE_FLG | Global Partitioned | RANGE(D1_ USAGE_ID) | |||
D1T316S0 | REL_USAGE_ID, USAGE_REL_TYPE_FLG, D1_USAGE_ID | Global Partitioned | HASH(REL_USAGE_ID, USAGE_REL_TYPE_FLG, D1_USAGE_ID) | |||
D1_USAGE_ SCALAR_DTL | REFERENCE(D1_USAGE_SCALAR_DTL_FK) | |||||
D1T282P0 | D1_USAGE_ID, D1_SP_ID, SEQ_NUM | Global Partitioned | RANGE(D1_ USAGE_ID) |
D1_USAGE_ EXCP (Parent) | RANGE (ILM_DT, USAGE_EXCP_ID) | D1_USAGE_ EXCP. CRE_DTTM | ||||
D1T443P0 | USAGE_EXCP_ID | Global Partitioned | RANGE (USAGE_EXCP_ ID) | |||
CM_ILM_D1T443S1 | ILM_DT, ILM_ARCH_SW, USAGE_EXCP_ID | Local Partitioned | ||||
D1_USAGE_ EXCP_CHAR | REFERENCE (D1_USAGE_ EXCP_CHAR_ FK) | D1T446P0 | USAGE_EXCP_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE (USAGE_EXCP_ ID) | |
D1T446S1 | SRCH_CHAR_VAL | Global Partitioned | HASH (SRCH_CHAR_ VAL) | |||
D1_USAGE_ EXCP_PARM | REFERENCE (D1_USAGE_ EXCP_PARM_ FK) | D1T445P0 | USAGE_EXCP_ID, PARM_SEQ | Global Partitioned | RANGE (USAGE_EXCP_ ID) |
D1_VEE_EXCP (Parent) | RANGE(ILM_DT, VEE_EXCP_ID) | D1_VEE_EXCP. CRE_DTTM | ||||
D1T308P0 | VEE_EXCP_ID | Global Partitioned | RANGE (VEE_EXCP_ID) | |||
D1T308S1 | INIT_MSRMT_DATA_ID | Global Partitioned | HASH(INIT_ MSRMT_DATA_ID) | |||
CM_ILM_D1T308S2 | ILM_DT, ILM_ARCH_SW, VEE_EXCP_ID | Local | ||||
D1_VEE_EXCP_CHAR | REFERENCE (D1_VEE_EXCP_ CHAR_FK) | |||||
D1T310P0 | VEE_EXCP_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | RANGE(VEE_ EXCP_ID) | |||
D1T310S1 | SRCH_CHAR_VAL | Global Partitioned | HASH(SRCH_CHAR_VAL) | |||
D1_VEE_EXCP_PARM | REFERENCE (D1_VEE_EXCP_ PARM_FK) | |||||
D1T309P0 | VEE_EXCP_ID, PARM_SEQ | Global Partitioned | RANGE(VEE_ EXCP_ID)) |
D1_SP_SNAP_DL | RANGE(ILM_DT, SP_SNAP_ID) | D1_SP_SNAP_DL.SNAPSHOT_ DTTM | ||||
D1T434P0 | SP_SNAP_ID | Global Partitioned | RANGE(SP_SNAP_ID) | |||
D1T434S0 | D1_SP_ID, SNAPSHOT_DTTM, SNAPSHOT_TYPE_FLG | Global | ||||
CM_ILM_D1T434S1 | ILM_DT, ILM_ARCH_SW, SP_SNAP_ID | Local | ||||
D1_SP_UNR_ USG_SNAP_DL | RANGE(ILM_DT, SP_UNR_USG_ SNAP_ID) | D1_SP_UNR_USG_SNAP_DL.SNAPSHOT_DTTM | ||||
D1T438P0 | SP_UNR_USG_SNAP_ID | Global Partitioned | RANGE(SP_UNR_USG_SNAP_ID) | |||
D1T438S0 | D1_SP_ID, SNAPSHOT_DTTM, UNR_USG_SNAPSHOT_ TYPE_FLG, SNAPSHOT_TYPE_FLG | Global | ||||
CM_ILM_D1T438S1 | ILM_DT, ILM_ARCH_SW, SP_UNR_USG_SNAP_ID | Local | ||||
D1_SP_USG_ SNAP_DL | RANGE(ILM_DT, SP_USG_SNAP_ ID) | D1_SP_USG_SNAP_DL.SNAPSHOT_DTTM | ||||
D1T436P0 | SP_USG_SNAP_ID | Global Partitioned | RANGE(SP_USG_ SNAP_ID) | |||
D1T436S0 | D1_SP_ID, SNAPSHOT_DTTM, MEASR_COMP_ID, USG_SNAPSHOT_TYPE_FLG, D1_TOU_CD, MSRMT_COND_FLG, SNAPSHOT_TYPE_FLG | Global | ||||
CM_ILM_D1T436S1 | ILM_DT, ILM_ARCH_SW, SP_USG_SNAP_ID | Local | ||||
D1_SP_VEE_ EXCP_SNAP_DL | RANGE(ILM_DT, SP_VEE_EXCP_ SNAP_ID) | D1_SP_VEE_ EXCP_SNAP_ DL.SNAPSHOT_ DTTM | ||||
D1T440P0 | SP_VEE_EXCP_SNAP_ID | Global Partitioned | RANGE(SP_VEE_ EXCP_SNAP_ID) | |||
D1T440S0 | D1_SP_ID, SNAPSHOT_DTTM, MEASR_COMP_ID, EXCP_TYPE_CD, D1_IMD_TYPE_FLG, EXCP_SEVERITY_FLG, VEE_GRP_CD, VEE_RULE_CD, SNAPSHOT_TYPE_FLG | Global | ||||
CM_ILM_D1T440S1 | ILM_DT, ILM_ARCH_SW, SP_VEE_EXCP_SNAP_ID | Local |
D1_INIT_MSRMT_SNAP (Parent) | Range(ILM_DT, INIT_MSRMT_ SNAP_ID) | D1T622P0 | INIT_MSRMT_SNAP_ID | Global Partitioned | Range(INIT_ MSRMT_SNAP_ID) | D1_INIT_MSRMT_SNAP.CRE_ DTTM |
CM_ILM_D1T622L0 | ILM_DT, ILM_ARCH_SW, INIT_MSRMT_SNAP_ID | Local Partitioned | ||||
D1_INIT_MSRMT_SNAP_CHAR | Reference Partitioning | D1T624P0 | INIT_MSRMT_SNAP_ID, CHAR_TYPE_CD, SEQ_NUM | Global Partitioned | ||
D1_INIT_MSRMT_SNAP _LOG | Reference Partitioning | D1T625P0 | INIT_MSRMT_SNAP_ID, SEQNO | Global Partitioned | ||
D1_INIT_MSRMT_SNAP _LOG_PARM | Reference Partitioning | D1T626P0 | INIT_MSRMT_SNAP_ID, SEQNO, PARM_SEQ | Global Partitioned |
D1_MDSI (Parent) | Range(ILM_DT, D1_MDSI_ID) | D1T565P0 | D1_MDSI_ID | Global Partitioned | Range(D1_MDSI_ ID) | D1_MDSI_ START_DTTM |
CM_ILM_D1T565L0 | ILM_DT, ILM_ARCH_SW, D1_MDSI_ID | Local Partitioned |
D1_MDSS (Parent) | Range(ILM_DT, D1_MDSS_ID) | D1T594P0 | D1_MDSS_ID | Global Partitioned | Range(D1_MDSS_ID | D1_MDSS_ START_DTTM |
CM_ILM_D1T594L0 | ILM_DT, ILM_ARCH_SW, D1_MDSS_ID | Local Partitioned |
D1_ACTIVITY (Parent) | RANGE (ILM_DT, RETENTION_ PERIOD) | D1_ACTIVITY. CRE_DTTM | ||||
CM_ILM_D1T319S1 | ILM_DT, RETENTION_PERIOD, ILM_ARCH_SW, D1_ACTIVITY_ID | Local | ||||
D1_ACTIVITY_CHAR | REFERENCE (D1_ACTIVITY_ CHAR_FK) | |||||
D1T330S0 | ACTIVITY_ID_TYPE_ FLG, ID_VALUE | Global Partitioned | HASH(ACTIVITY_ID_TYPE_FLG, ID_VALUE) | |||
D1T330S1 | ACTIVITY_ID_TYPE_ FLG, UPPER(ID_VALUE) | |||||
D1_ACTIVITY_REL_OBJ | REFERENCE (D1_ACTIVITY_REL_OBJ_FK) | |||||
D1T324P0 | D1_ACTIVITY_ID, MAINT_OBJ_CD, ACTIVITY_REL_OBJ_ TYPE_FLG | Global Partitioned | RANGE(D1_ ACTIVITY_ID) | |||
D1_DVC_EVT (Parent) | RANGE(ILM_DT, RETENTION_ PERIOD) | D1_DVC_EVT. CRE_DTTM | ||||
CM_ILM_D1T400S4 | ILM_DT, RETENTION_PERIOD, ILM_ARCH_SW, DVC_EVT_ID | Local | ||||
D1_DVC_EVT_ CHAR | REFERENCE (D1_DVC_EVT_ CHAR_FK) | |||||
D1_DVC_EVT_LOG_PARM | REFERENCE (D1_DVC_EVT_LOG_PARM_FK) | |||||
D1_DVC_EVT_REL_OBJ | REFERENCE (D1_DVC_EVT_ REL_OBJ_FK) | |||||
D1_INIT_MSRMT_DATA (Parent) | RANGE (ILM_DT, RETENTION_ PERIOD) | D1_INIT_MSRMT_DATA. CRE_DTTM | ||||
D1T304S1 | MEASR_COMP_ID, BO_STATUS_CD, BUS_OBJ_CD, D1_TO_DTTM, D1_FROM_DTTM | Global Partitioned | RANGE (MEASR_COMP_ID) | |||
CM_ILM_D1T304S4 | ILM_DT, RETENTION_PERIOD, ILM_ARCH_SW, INIT_MSRMT_DATA_ID | Local | ||||
