Enhancements in Oracle Utilities Meter Data Management
This section describes new features and functionality included in this release of Oracle Utilities Meter Data Management, including:
User Experience Enhancements
This section describes the new and enhanced user experience features in this release, including:
Operational Dashboard Filter
In this release, the following zones on the Meter Operational Dashboard allow you to filter data by Division Code:
Incomplete IMDs by Status
Incomplete IMDs Trend
VEE To Dos by Exception Type
VEE To Dos Trend
Usage Transaction by Status
Usage Transaction Trend
Usage Transaction To Dos by Exception
Usage Transaction To Dos Trend
Steps to Enable
To enable this feature, turn on Division Security in Master Configuration and set up the users' default divisions.
Meter Health Check
You can check the health of the system or monitor the state of the environment through accessing the different dimensions of meter data, such as the count of Initial Measurement Data records by:
Status: Pending, Error, and so on
Type: scalar and interval
Counts, averages and total
You can collect a set of data points over time to track the health of environment regularly and take appropriate actions. The tool also enables you to export data or results in Microsoft Excel or in printed formatted.
Steps to Enable
To enable this feature, refer to the Configuring the Meter Health Check Dashboard section of the Oracle Utilities Meter Data Management Administrative User Guide for more information.
Device and Service Point Enhancements
This section describes the new and enhanced device and service point features in this release, including:
Initial Measurement Data Monitor Batch Controls
The following Initial Measurement Data (IMD) Monitor batch controls minimize performance issues when adding large numbers of historical or backlog readings. These use the IMD as the processing work unit instead of the Device Configuration. This prevents situations in which an error on an IMD rolls back processing for all of the IMDS for a given device configuration. These include:
D1-IMDV2 (IMD Monitor - Physical Devices V2): used to process initial measurements related to physical devices.
D1-IMDD2 (IMD Monitor - Deferred IMDs V2): used to process previously held or deferred IMDs.
D1-IMDM2 (IMD Monitor - Unattached MCs V2): used to process IMDs for standalone measuring components without a Device Configuration such as weather or price data.
In addition, these batch controls provide more frequent commits that:
Ensure consistent records per second processing
Preserve process during a thread shut down
Isolate failures to a single IMD
Steps to Enable
No steps are required to enable this feature.
Tips And Considerations
The D1-IMDV2 batch control invokes monitoring rules associated with the current state of an Initial Measurement Data (IMD). All monitoring rules throughout the IMD's business object's inheritance chain are considered.
The D1-IMDV2 batch parameters govern whether the processing is further restricted by batch code, business object, status, and so on.
The D1-IMDV2 batch process is based on the standard monitor process. However, it does not need to be plugged in on a state of the IMD business objects as a "Monitor Process". You do not need to change your IMD business objects to reference this new batch control.
The D1-IMDV2 batch parameter "runAsBatchCode" can be used to process records where the current status is governed by "Run as Batch Control" when the parameter is not plugged in as a Monitor Process. For example, if there is an IMD in PENDING where the BO status is configured with a "Monitor Process" of D1-IMD then setting the "Run as Batch Control" to D1-IMD will allow this batch control to transition that record.
The D1-IMDV2 batch control processes all IMDs for a Measurement Component up to and including that limit and each additional IMD will be held if the optional parameter for Measuring Component IMD Limit is configured. For the held IMDs, there are some optional behaviors:
A To Do entry can be created for each Measurement Component with more than the configured limit of IMDs. Note that only one To Do entry per Measurement Component is created even if there is more than one IMD over the limit.
The IMDs over the limit can be transitioned to a new status to remove these from the normal processing flow. This ensures these are not picked up on a subsequent run of the D1-IMDV2 batch control and that these must be processed using the D1-IMDD2 batch control.
Updated Initiation for Measurement Reprocessing
Measurement Reprocessing is initiated when install event dates change. Previously, measurement reprocessing was only initiated when the installation constant was changed. When the installation and removal dates expand to cover a longer time, this process checks for existing measurements that require a change in multiplier and reprocessing.
This update reduces manual work, project cost, and configuration time. It also increases process automation and customer satisfaction.
Steps to Enable
Usage Calculation Enhancements
This section describes the new and enhanced usage calculation features in this release, including:
Usage Calculation Rule - Demand at Service Point Level
The "Coincident Peak and Individual SP Demand" usage calculation rule enables you to determine demand at the service point level based on:
Individual Service Points
Coincident Peaks
Time-of-Use (TOU) Coincident Peaks
Previously, demand was only calculated at the subscription level. This usage calculation rule reduces implementation and support costs.
Steps to Enable
To enable this feature, refer to the Usage Calculation Rules section of the Oracle Utilities Meter Data Management Administrative User Guide for more information.
Usage Calculation Rule - Rolling Demand
The Rolling Demand usage calculation rule allows you to support meters that record intervals at one interval length (for example, a 15 minute interval) and tariffs that require demand values to be calculated at higher interval lengths (for example, 30 minute intervals). This allows you to bill rolling demand in a standardized way across various interval rates.
Steps to Enable
Integration and Data Extract Enhancements
This section describes the new and enhanced integration and data extract features in this release, including:
DataConnect Interval AMI Extract - Additional Data
The "Interval AMI" DataConnect data extracts now include the following data:
Service Quantity Identifier
Time of Use
Service Type
Device Id (meter number (customer-facing))
These extracts can be used for Opower integration or as integration to other energy management systems. These provide more detailed interval data extracts. It also reduces project cost and configuration time.
Steps to Enable
To enable this feature, refer to the Oracle Utilities DataConnect / Opower section of the Oracle Utilities Meter Data Management Administrative User Guide for more information.
Measurement and Initial Measurement Data Header Extract-related Batch Processes
These batch controls streamline the initial export of Measurement data and Initial Measurement Data (IMD) header data:
Specialized IMD Header Initial Extract (D1-SIMDI) - Extracts IMD headers of IMDs whose "To" date/time are later than the Start Date/Time and equal or earlier than the End Date/Time
Specialized Measurement Initial Extract (D1-SMDIE) - Extracts measurements whose Measurement date/time are later than the Start Date/Time and equal or earlier than the End Date/Time.
Additionally, you can extend the default SQL Timeout value (900 seconds) of the Specialized IMD Header Extract Current (D1-SIMDC) or Specialized Measurement Extract Current (D1-SMDECS) batch control with the "Override SQL Timeout" parameter.
Steps to Enable
Miscellaneous Enhancements
This section describes the new and enhanced estimation features in this release, including:
Non-final Initial Measurement Data Self-service Removal Tool
You can identify and remove unnecessary Initial Measurement Data (IMDs) in "non-final" status with a self-service tool that enables you to filter IMDs by date range, business object, business object status, and device configuration. This allows you to perform quick data cleanup and reduces manual record deletion.
Steps to Enable
