Dedicated To Do Background Processes
There are To Do entries that are created by system background processes whose main purpose is to create To Do entries based on a given condition. For these background processes, the To Do Type indicates the creation background process.
Note that the Plug-in Driven batch program cannot be used for this purpose. This program assumes that any To Do Type that references it as a creation process is using the link for the Object-Specific Error Condition use case. If you want to use the plug-in driven batch process to create To Do entries based on a given condition, then you need to follow the pattern described in To Dos Created by Background Processes for Specific Conditions.
If you don't schedule the background process, the entries
will not be created! The To Do entries of this type will
only be created if you have scheduled the associated background process.
Therefore, if you want the system to produce a given entry, schedule
the background process.
