Save As
The Save As... option in the Explorer Zone menu allows a user to save the current entered search criteria. This should be clicked after executing the search.
The user is prompted to provide a name for the search. This search is now available from the Open Saved Searches option. If desired, a user can also choose to make this search the Default or may choose to Add to Favorites.
This option is visible whether or not an existing saved search is loaded. When a saved search is loaded, this option allows a user to make changes to the search criteria and save a new search with that criteria.
