Raise Missing Quantity Exception
This rule flags any missing interval data while providing a soft parameter on the algorithm to exclude a condition range if desired.
Additional detail on the logic of this rule can be found in the Detailed Description of the D2-RAIMISQTY Algorithm Type.
For help with the meaning of specific configuration fields, refer to the embedded help on the screen when adding or editing the rule.
Business Object
D2-RaiseMissingQuantityExcp
