About Measuring Components
Measuring components are single points for which data will be received and stored in the system.
A measuring component can be associated to a device, which can have one or more measuring components, or it can be "virtual" or "stand-alone," meaning that it is not associated to a device.
The base package supports the following types of measuring components:
Physical
: Physical measuring components are those that physically exist, and that
are linked to a device that can be configured differently over time. Interval channels and
scalar registers are examples of physical measuring components. Note: The terms register and channel are synonyms for measuring component.
- Standalone: A standalone measuring component is used to record measurements for something that does not have a physical presence or is not associated to a particular device or service point. For example, you might create a standalone measuring component to record the average daily temperature supplied by a weather station. Standalone measuring components can be identified through Standalone Identifier.
- Scratchpad : Users create scratchpad measuring components based on physical measuring components to experiment with measurement manipulation functions.
- External : External measuring components are used to model measuring components for data that is not stored in the system. For example, some meters may have channels (measuring components) that capture Amps or other data not used my Meter Data Management or Customer to Meter, but that should be passed on to other external systems such as Oracle Energy and Water Data Intelligence. Incoming data for external measuring components of this type can be filtered or passed through to other systems, preventing errors generated by incoming data for measuring components that don't exist.
Aggregator: An aggregator measuring component holds summarized usage from
other measuring components. For example, aggregator measuring components could be configured
to hold total consumption for each postal code within a service territory. Head end system
processing statistics used by Oracle Utilities Smart Grid Gateway are stored as aggregated
measurements for aggregator measuring components.Refer to About Aggregations for additional functional information about aggregation measuring components.
Attributes used to define measuring components can include the following:
- The measuring component type
- The device configuration to which the measuring component is associated
- Details concerning how the measuring component is read, such as the number of digits, the type of read out (dials or digital), the meter multiplier, etc.
- Initial Load IMD Ordering: A flag that indicates if incoming initial measurements for the measuring component should be processed using Measuring Component Ordering. This is used most often in the case of daily scalar measuring components for which data is occasionally sent to the system out of order, but can also be used to ensure that "check channels" are processed before related channels. Applicable only to measuring component types used with Direct Measurement Processing (see Direct Measurement Processing and Measuring Component Ordering for more information).
- The VEE groups used for validation and estimation of measurement data. Refer to About VEE for details about the types of VEE groups supported.
- Enable ML Based Validation: A flag that indicate (Yes or No) if initial measurements for the measuring component will be processed through a machine learning scoring model. IF set to "Yes", VEE processing for initial load data will only be used when data fails machine learning normalcy checks. See Machine Learning Anomaly Scoring for more information.
Scalar vs. Interval
Beyond the four types described above, measuring components generally fall into one of two primary classes of: scalar measuring components, and interval measuring components.
- Scalar measuring components are measured at unpredictable intervals. For example, "once a month" is not a predictable interval as the amount of time between reads in unpredictable and inconsistent.
- Interval measuring components are measured at predictable intervals, such as every 15 minutes, every 30 minutes, every hour, etc.
- The terms "interval size" and "seconds-per-interval" (SPI) are used to define the size of an interval measuring component's intervals.
- Note: A device may have any combination of interval and/or scalar measuring components
Measuring Component Measurements
Measuring components are configured to measure specific types of quantities. These include:
- Unit of Measure: The unit of measure for the quantity being recorded. Examples include kilo-watt hours (kWh), kilo-watts (kW), therms, cubic feet (CCF), temperature (Fahrenheit or Celsius), etc.
- Time of Use: Modifiers for a given unit of measure that indicate a period of time during which a quantity has been used, such as On-Peak (meaning during a time when the greatest quantity of some consumable is being used), Off-Peak (meaning during a time when the least amount of some consumable is being used), etc.
- Service Quantity Identifiers: Used to further distinguish between measured quantities that have identical UOM/TOU combinations, including situations in which the distinguishing identifier of a UOM is not accurately described as a TOU. Generally, SQI is only used when multiple measuring components measure the same thing, but in different ways. A meter that measures both generation KWH and consumption KWH could use SQIs to differentiate between the two.
The combination of UOM, TOU and SQI define what a measuring component measures. TOU and SQI are optional, but UOM must be defined for all measuring components. For example, consider a meter (as illustrated in the image below) with two measuring components, both measuring the same unit of measure (kWh), but each measuring component measures consumption in different time of use (TOU) periods (peak and off-peak).
Subtractive vs. Consumptive Measurements
Another attribute that defines how measuring components measure quantities is the distinction between subtractive and consumptive measuring components.
A subtractive measuring component's usage is equal to the current reading (also known as the Stop or End Measurement or Reading) minus the previous reading (also known as the Start Measurement or Reading). To put this more simply:
Usage = End Reading - Start Reading
Most residential scalar meters are subtractive and in some cases interval meters can be subtractive as well . The table below lists a series of measurements for a subtractive measuring component.
| Date | kWh (Reading) | Usage |
| 01/01/2010 | 0 | |
| 01/31/2010 | 1000 | 1000 kWh |
| 03/02/2010 | 1780 | 780 kWh |
| 04/01/2010 | 2700 | 920 kWh |
A consumptive measuring component's usage is equal to its current measurement. Most residential interval meters are subtractive. For scalar, consumptive measuring components are often used to measure demand, such as KW. The table below lists a series of measurements for a consumptive scalar measuring component.
| Date | KW (Reading) | Usage |
| 01/01/2010 | 0 | 0 KW |
| 01/31/2010 | 10 | 10 KW |
| 03/02/2010 | 10 | 10 KW |
| 04/01/2010 | 13 | 13 KW |
