Dimension Scanning
The Aggregation Group holds the monitor algorithm that performs the scanning
The Data Source defines the template SQL for identifying dimensions
Measuring Component Sets define the dimensions and criteria for identifying the dimension combinations
Identifies all Measuring Component Sets for the Aggregation Group that are not imported from an external source
Identifies all yet to be represented dimension combinations
Creates an Aggregation Measuring Component based on the Measuring Component Set's Measuring Component Type for each dimension combination identified in step 2.
Adds Attributes for each Aggregation Measuring Component created to describe the dimensions and criteria for that Measuring Component
Adds an entry in the Measuring Component Set participants table for each Aggregation Measuring Component created
This processing is performed by a monitor algorithm (Aggregation Group Dimension Scanner: D1-AGDS) on the Finalized status of the Aggregation Group business object.
