Defining Portals
This portal is used to view and maintain the configuration of portals. An implementation may define their own portals or may override some of the settings for base product provided portals.
You can access the portal from the . You are brought to a query portal with options for searching for a specific record. Once a portal record has been selected you are brought to the maintenance portal to view and maintain the selected record.
Note: When introducing a new record, carefully consider its naming convention. Refer to  System Data Naming Convention for more information.
Refer to Understanding Portals and Zones for more information.
The following zones may appear as part of the portal's Main tab page
- Portal. This zone provides information about the selected portal definition.
- Tabs. This zone lists other tab portals if any are configured for a standalone portal. This zone is only visible when such tabs exist for the current standalone portal.
- Context Sensitive Zones. This zone lists context sensitive zones that appear on the sidebar when this portal is displayed . This zone is only visible when such zones exist for the current standalone portal.
The following zones may appear as part of the portal's Options tab page
- Options. This zone lists various configuration options for the selected portal record.
