Batch Message Processing
Your implementation may be required to send messages to the same destination as a single XML file with multiple messages include. The following points describe this logic:
The individual messages that should be grouped together must have a processing method of batch on the external system / outbound message type record. The appropriate batch code that is responsible for grouping the messages must also be provided.
A separate "consolidated message" outbound message type should be configured for the external system with a processing method of SOA.
When outbound message records are created for the individual messages, the batch code and current batch run number are stamped on the record.
When the batch process runs it is responsible for building the XML file that is a collection of the individual messages. This batch process should include the following steps: -
Format appropriate header information for the collection of messages
Apply the individual message XSL to each message before including the message
Insert a new outbound message for the external system with the "consolidated message" outbound message type.
The consolidated message is ready to be processed by Oracle Service Bus.
