Defining Business Services
Use this page to define basic information about a Business Service.
You can access the portal from the . You are brought to a query portal with options for searching for a specific business service. Once a business service has been selected you are brought to the maintenance portal to view and maintain the selected record.
CAUTION: Important! If you introduce a new business service,
carefully consider its naming convention. Refer to  System Data Naming
Convention for more information.
The following zones may appear as part of the portal's Main tab page.
- Business Service. This zone provides information about the selected business service.
- Schema Editor. This zone describes the business service's schema and supports basic edits in plain text. Refer to the Schema tab below for additional schema editor information.
The following zones may appear as part of the portal's Schema tab page.
Schema Editor. This zone allows you to edit the business service's schema using
the Schema
Designer tool. The purpose of the schema is to describe the business service's
properties and map them to the underlying internal service fields.Fastpath: Refer to Schema Syntax and UI Hint syntax for a complete list of the XML nodes and attributes available to you when you construct a schema.Tip: Click the View Schema hyperlink to view the business service's expanded schema definition. Doing this opens the schema viewer window.
The following zones may appear as part of the portal's References tab page.
- Business Service References. This zone list various configuration entities referencing the current business service or its schema.
Actions
The page supports the following special actions:
- View Schema. Click the hyperlink to view the business service's expanded schema definition. Doing this opens the schema viewer window.
Test.  Use this action to test your business service. Enter input values and
save. The service is  performed and output information is presented. If the service
issues an error the corresponding message is displayed. Note that the input and
output testing user interface is dyamically rendered based on UIHints embedded in the
business service's schema. As such, the user interface may be as elaborate or basic
as the UIhints in that schema.Note: This action is secured by a designated "Test a Service" application service and requires also security rights for creating a script, which is the alternative way for testing any service. It is recommended to allow access to this function in non-production environments only.
