Defining Data Areas
Use this page to define basic information about a data area.
You can access the portal from the . You are brought to a query portal with options for searching for a specific data area. Once a data area has been selected you are brought to the maintenance portal to view and maintain the selected record.
CAUTION: Important! If you introduce a new data area, carefully
consider its naming convention. Refer to  System Data Naming
Convention for more information.
The following zones may appear as part of the portal's Main tab page.
- Data Area. This zone provides information about the selected data area.
- Extending Data Areas. This zone lists all data areas extending the current data area. The zone appears if such data areas exist.
- Schema Editor. This zone describes the data area's schema and supports basic edits in plain text. Refer to the Schema tab below for additional schema editor information.
The following zones may appear as part of the portal's Schema tab page.
Schema Editor. This zone allows you to edit the data area's schema using the Schema Designer
tool. The purpose of the schema is to describe the data area's properties and map them to
the underlying internal service fields .Fastpath: Refer to Schema Syntax and UI Hint syntax for a complete list of the XML nodes and attributes available to you when you construct a schema.Tip: Click the View Schema hyperlink to view the data area's expanded schema definition. Doing this opens the schema viewer window.
The following zones may appear as part of the portal's References tab page.
- Data Area References. This zone list various configuration entities referencing the current data area or its schema.
Actions
The page supports the following special actions:
- View Schema. Click the hyperlink to view the data areas's expanded schema definition. Doing this opens the schema viewer window.
