Meter Attribute Administration Services
This section describes the meter administration services of the test harness composite.
GetLoadActionCode
This web service queries whether the given meter is connected or disconnected. This method is used by the Connect/Disconnect service. The values for load action code are:
Connect
Disconnect
Input — GetLoadActionCodeInput
Part: payload
Element: GetLoadActionCodeRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter for which the load action code status should be retrieved  |
Output — GetLoadActionCodeOutput
Part: payload
Element: GetLoadActionCodeResult
The connection status of the requested meter.
Fault — See UtilityFault. Thrown when meter id is not found.
SetLoadActionCode
This web service updates the load action code for a given meter. This method is used by the Connect/Disconnect service. The values for load action code are:
Connect
Disconnect
Input — SetLoadActionCodeInput
Part: payload
Element: SetLoadActionCodeRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter for which the load action code status should be set.  |
 value  |
 The new value of LoadActionCode to set on the meter.  |
Output — SetLoadActionCodeOutput
Part: payload
Element: SetLoadActionCodeResult
The boolean response indicates the success or failure of the update (not the current field status).
IsCommissioned
This web service queries the commissioning status for a given meter. This service is used by the Commission/Decommission process. The commissioning attribute can be true or false.
Input — IsCommissionedInput
Part: payload
Element: IsCommissionedRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter for which the Commissioned status should be retrieved  |
Output — IsCommissionedOutput
Part: payload
Element: IsCommissionedResult
The value of the Commissioned status attribute for the requested meter.
SetCommission
This web service updates the commissioning status for a given meter. This service is used by the Commission/Decommission process. The commissioning attribute can be true or false.
Input — SetCommissionedInput
Part: payload
Element: SetCommissionedRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter for which the Commissioned status should be set  |
 value  |
 The new value of Commissioned status to set on the meter  |
Output — SetCommissionedOutput
Part: payload
Element: SetCommissionedResult
GetExecutionStatus
This web service queries the status of the property controlling the overall execution of the command. The possible values of execution status are:
Success - The command should complete successfully
ResponseTimeout - The asynchronous response will never arrive
SyncOperationFail - A simulated fault will occur in the during the initial request
AsyncOperationFailure - A simulated fault will occur in the asynchronous response
Input — GetExecutionStatusInput
Part: payload
Element: GetExecutionStatusRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter for which the ExecutionStatus should be retrieved  |
Output — GetExecutionStatusOutput
Part: payload
Element: GetExecutionStatusResult
The value of the ExecutionStatus attribute for the requested meter.
SetExecutionStatus
This web service updates the property controlling the overall completion of the command. The possible values of execution status are:
Input — SetExecutionStatusInput
Part: payload
Element: SetExecutionStatusRequest
 Parameter  |
 Description  |
 id  |
 The ID for the meter for which the ExecutionStatus should be set  |
 value  |
 The new value of ExecutionStatus to set on the meter  |
Output — SetExecutionStatusOutput
Part: payload
Element: SetExecutionStatusResult
