What's New Portal
Important:
This is only available for cloud implementations.
The What's New portal provides a list of maintenance pack fixes that have been applied to your environment along with a summary of the maintenance packs that have been supplied along with their dates. There is also a link to view the Release Notes to see the new features added in your version.
To view the information, open the Help Menu in the toolbar and choose the What's New option.
The following zones appear on the Main page.
  • Maintenance Pack Details. This zone is populated whenever a maintenance pack or a hot fix is applied to your environment. By default it shows fixes applied in your current maintenance pack and it suppresses copies if your environment already received this fix in a previous release. Use the filters to expand the search to other releases or to include copies. There are also filters to narrow the search based on various criteria. Refer to the zone inline help for more information.
  • Installation History Summary. This zone is visible if you click the 'View Installation Summary' link in the previous zone. It shows a distinct list of installation date and version information.
Populating the zone with maintenance pack details is in Beta testing in this release. In your environment, the portal may exist without any content. Once the functionality is fully released, you will see content in this zone.
This zone only has fixes that were applied to your environment after the enhancement to populate this data was fully supported. The system is not populating this zone with fixes applied to your implementation prior to the enhancement.
