Custom Look and Feel Options
The default look and feel of the application can be customized via feature configuration. The base product is provided with a Custom Look And Feel Feature Configuration type. If you define a feature configuration of this type, you can adjust the look and feel in the following ways.
  • You may adjust the look and feel of the application using cascading style sheets. Refer to User Interface Style Customization for more information.
  • You may adjust configuration related to the display of the UI Map Help icon.
  • You may choose the "compact" view of the user interface. This option reduces the amount of white space for the rendered pages. To do this, define an entry for the UI View option type and enter a value of Compact.
