Defining Reporting Options
The reporting options are provided as a mechanism for defining information needed by your reporting solution. The base product uses the reporting options to define information needed to access the reporting tool from within the system using the algorithm defined on the installation option.
Navigate to this page using Admin > Reporting > Reporting Options.
Description of page
Reporting Folder defines the shared folder where reports are stored.
Reporting Server From Browser defines the URL of the web application where the reporting tool is installed. For example, using BI Publisher, the format is: http://<BI Publisher Server>:<port>.
Customize Options. The reporting options are customizable using the Lookup table. This field name is RPT_​OPT_​FLG. The reporting options provided with the system are needed to invoke the reporting tool. If your implementation requires other information to be defined as reporting options, use the lookup table to define additional values for the reporting option flag.
Where Used
This information is used by the reporting tool algorithm on the installation option to invoke the reporting tool software.
Implementations may use reporting options to record other information needed for their reporting tool.
