Message Sender - Main
To define a new sender, open Admin > Integration > Message Sender.
Description of Page
Enter a unique Message Sender and Description.
CAUTION:
Important! When adding new records, carefully consider the naming convention of the message sender code. Refer to System Data Naming Convention for more information.
Set Invocation Type to Real-time.
Indicate the Message Class for this sender, which indicates the method used to route the message. The valid sender classes are as follows:
Message Class Description
RTEMAILSNDR Email sender.
RTHTTPSNDR HTTP sender.
RTJMSQSNDR JMS queue sender.
RTJMSTSNDR JMS topic sender.
RTJSONSNDR HTTP JSON sender.
SOAPSNDR HTTP SOAP sender.
For backward compatibility, the sender class HTTPSNDR is also supported, but should only be used if indicated by a specific integration configuration.
Indicate whether or not this sender is currently Active.
For JMS related senders, indicate whether the Message Encoding is ANSI message encoding or UTF-8 message encoding. (Note that for all other types of senders, the Character Encoding context type is used to configure encoding.)
If the Message Class is one that connects to a JMS Queue or JMS Topic, indicate the appropriate JMS Connection
Fastpath:
Refer to JMS Connection for more information.
If the Message Class is one that connects to a JMS queue, indicate the name of the JMS Queue to define where the message is to be sent.
Fastpath:
Refer to JMS Queue for more information.
If the Message Class is one that connects to a JMS topic, indicate the name of the JMS Topic to define where the message is to be sent.
Fastpath:
Refer to JMS Topic for more information.
