Maintaining Managed Content
The Managed Content object is used to store various types of text content. Some content is used internally such as Allowlists. Other content may be used by implementations such as XSL files used for communicating messages with an external system, JavaScript include files, and CSS files. These files may then be maintained in the same manner as the HTML in UI Maps.
Open this page using Admin > System > Managed Content.
Use the Managed Content Query portal to search for an existing managed content entry. Once the managed content is selected, you are brought to the maintenance page to view and maintain the selected record.
Most fields on the page are self explanatory.
Use Managed Content Type to indicate the type of content.
  • Allowlist
    is used to capture a list of supported values for given functionality. For example, the product provides allowlists for SQL functions and valid HTML tags.
  • XSLTC is used to reference XSL files. These may be used internally for user interface referencing. Additionally, the XSLs may be referenced for sending messages to external system using outbound message and for receiving messages in SOAP as inbound messages.
The value F1X (XSLT) is no longer supported and will be deprecated in a future release. Other managed content values are not currently supported by any current framework functionality and are reserved for future use.
Use the Schema tab to view and maintain the contents of the managed context text.
