Scroll Bars with Dynamic Height
Sometimes the height of a grid isn't sufficient to display a grid's rows. When this occurs, a vertical scroll bar appears and an "expand button" appears above this bar, The Expand icon is a downward arrow.. For example, the following grid is not high enough to show all of a the available sidebar zones:
Screenshot of sidebar zones table. To the right, the scroll bar and the Expand button not expanded are shown.
If you want to view all of the available zones without using the vertical scroll bar, you can you click the expand button. When clicked, the height of the grid expands to show all rows in the grid:
Screenshot of sidebar zones table. To the right, the scroll bar and the Expand button expanded are shown.
Notice, after the grid is expanded, the grid's vertical scroll bar disappears and the button in the upper corner becomes a Collapse Button, Collapse Button. If you click the collapse button, the grid will return to its original height.
Search grids. Expand all functionality is not available in search grids.
