Batch Job Submission Portal
To view a submitted batch job, use Menu > Tools > Batch Job Submission. You are brought to a query portal with options for searching for a Batch Job Submisssion entry.
Once a batch job submission entry has been selected, you are brought to the maintenance portal to view the selected record.
The inline help provides information about several fields. Refer to Parameters Supplied to Background Processes for more information about the fields on this page.
Refer to On-Line Batch Submission for detailed explanations about many feaures of online submisssion.
Actions
This page has three special actions.
  • Using the Duplicate button opens a window with the selected batch job submisssion details displayed. These fields, including the batch parameter values, may be overidden. Pressing Save will create a new Batch Job Submission entry.
  • Use the Rerun button to rerun the selected batch job. A window opens displaying the details of the batch job submisssion to be rerun. These fields, including the batch parameter values, may be overidden. Pressing Save will create a rerun Batch Job Submission entry.
    Rerun is only intended to be used for background processes that download information that belongs to given run number. It is typically only required if you need to download an historical run (rather than the latest run).
  • Cancel is only applicable for batch job submisssions that are in Pending or Started status and do not have a submission method of Scheduled . The action is not visible for other statuses. Refer to Lifecycle of a Batch Job Submission for more information.
