Upgrade Procedure
The upgrade installation procedure consists of:
Upgrading the Database Component
Upgrade of the database component of Oracle Utilities Market Settlements Management must be complete before you can proceed with the following sections.
For instructions to upgrade the database component, refer to the Upgrade Install section in Oracle Utilities Market Settlements Management Database Administrator’s Guide.
Upgrading Application Components
A successful upgrade consists of the following steps:
Upgrading the Oracle Utilities Application Framework V25.4 Application Component
This section describes how to upgrade the application component of Oracle Utilities Application Framework, including:
Copying and Decompressing Install Media
The Oracle Utilities Application Framework V25.4 installation file is delivered as a zip file for both UNIX and Windows platforms. If you are planning to install multiple Oracle Utilities Application Framework V25.4 environments operated by different Oracle Utilities administrator user IDs, you must complete the following installation steps for each administrator user ID.
To copy and decompress the install media:
1. Login to the application server host with the Oracle Utilities Application Framework administrator user ID.
2. Download the Oracle Utilities Application Framework V25.4 Multiplatform from Oracle Software Delivery Cloud.
3. Create a temporary directory, such as c:\ouaf\temp or /ouaf/temp. (Referred to below as <TEMPDIR>)
Note: This directory must be located outside any current or other working Oracle Utilities application environment. All files that are placed in this directory as a part of the installation can be deleted after completing a successful installation.
4. Copy the downloaded application zip file to the <TEMPDIR>.
5. Decompress the file.
cd <TEMPDIR>
unzip -q <INSTALL MEDIA ZIP FILE NAME>
A sub-directory named FW-V25.4 is created. It contains the installation software for the Oracle Utilities Framework Application server.
Setting Permissions for the cistab file in UNIX
Every Oracle Utilities Application Framework environment installed on a server must be registered in the /etc/cistab file located on that server. On UNIX servers, generally only the root user ID has write permissions to the /etc directory. Since the installation process is run by the Oracle administrator user ID (cissys), this user ID may not be able to write to /etc/cistab table.
The install utility checks permissions and if it identifies a lack of the necessary permissions, it generates a script in the <TEMPDIR>/FW-V25.4 directory named cistab_<SPLENVIRON>.sh. Run the generated script using the root account before continuing with the installation process. The script initializes the cistab file in /etc directory (if it is the first Oracle Utilities Framework application environment on the server) and registers a new environment.
The generated script also changes the owner of /etc/cistab file to the Oracle Utilities Framework administrator user ID, so that the next time a new environment is created by the same Oracle Utilities Framework administrator user ID, you do not need to run the generated script with the root user ID. Instead the install utility itself proceeds with the registration.
If you are reinstalling an existing environment, only the validation of /etc/cistab entry is done by the install utility, no new registration occurs. The install utility interactively instructs you about every step that needs to occur in each specific case.
If you are planning to upgrade an existing environment it is your responsibility to take a backup prior to the upgrade process. The installation utility does not create a backup of existing environment.
Upgrading the Application Component
Oracle Utilities Market Settlements Management v25.4 supports upgrade from v2.3.0.2.0 or v2.5.0.1.1 to v25.4.
Oracle Utilities Market Settlements Management 25.4 supports the following upgrade paths:
From Oracle Utilities Market Settlements Management version prior to 2.3.0.2.0 to v25.4, install v2.3.0.2.0 before upgrading to v25.4.
From Oracle Utilities Market Settlements Management v2.4.0.0.0 to v25.4, install v2.5.0.1.1 before upgrading to v25.4.
From Oracle Utilities Market Settlements Management v2.5.0.0.0 to v25.4, install v2.5.0.1.1 before upgrading to v25.4.
To install the Oracle Utilities Application Framework V25.4 application component:
1. Login to the Application Server host as administrator (the default is cissys on UNIX) or as a user with Administrator privileges (on Windows).
2. Change directory to the bin folder.
cd <install_dir>/bin
<install_dir> is the location where the Oracle Utilities Application Framework base application component is installed.
3. Initialize the environment by running the appropriate command:
UNIX
./splenviron.sh -e <ENV NAME>
Windows
splenviron.cmd -e <ENV NAME>
4. Change directory to <TEMPDIR>/FW-V25.4.
Note: While installing the FW V25.4 from the previous environment to V25.4, the install utility removes the existing environment and re-creates the environment. Take a backup before you proceed with installing FW V25.4 to retain any configurations for future reference.
5. Start the application installation utility by executing the appropriate script:
UNIX:
ksh ./install.sh
Windows:
install.cmd
The Oracle Utilities Application Framework specific menu appears.
6. Follow the messages and instructions that are produced by the application installation utility.
7. Select each menu item to configure the values. For detailed description of the values, refer to Installation and Configuration Worksheets.
8. The following is the mandatory list of configurable items with descriptions for a few items. Where you see <Mandatory>, enter values suitable to your environment. You can assign default values to the rest of the menu items.
* Environment Installation Options *
1. Environment ID, Roles, Third Party Software Configuration
Environment ID
<Default>
Server Roles
batch, online
Oracle Client Home Directory
<Mandatory for Initial Install>
Web Java Home Directory
Hibernate JAR Directory
ONS JAR Directory
<Optional>
Web Application Server Home Directory
Additional JAR Directory
<Optional>
2. Keystore Options
Import Keystore Directory
<Default>
50. Environment Installation Options
Environment Mount Point
<Mandatory>
Log Files Mount Point
<Mandatory>
Environment Name
<Mandatory>
Install Application Javadocs
true
Install Sample CM Source Code
true
Each item in the above list should be configured for a successful install.
Choose option (1,2,50, <P> Process, <X> Exit):
Once you enter 'P' after entering mandatory input values in the above menu, the system populates another configuration menu.
* Environment Configuration *
1. Environment Description
<Mandatory>
2. Business Application Server Configuration
Business Server Host
<Mandatory> - Hostname on which application being installed
Business Server Application Name
SPLService
3. Web Application Server Configuration
Web Server Host
<Mandatory>
WebLogic SSL Port Number
<Mandatory>
WebLogic Console Port Number
<Mandatory>
Web Context Root
ouaf
WebLogic JNDI User ID
<Mandatory>
WebLogic JNDI Password
<Mandatory>
WebLogic Server Name
myserver
Web Server Application Name
SPLWeb
This Is A Production Env. And The Client Is Live
WEB_ISLIVEPRODUCTION
Deploy Javadocs Module
true
Enable The Unsecured Health Check Service
false
MDB RunAs User ID
<Mandatory>
Super User IDs
<Mandatory>
4. Database Configuration
Application Server Database User ID
<Mandatory>
Application Server Database Password
<Mandatory>
Batch Database User ID
<Mandatory>
Batch Database Password
<Mandatory>
Web JDBC DataSource Name
<Optional>
Database Name
<Mandatory>
Database Server
<Mandatory>
Database Port
<Mandatory>
ONS Server Configuration
<Optional>
Database Override Connection String
<Optional>
Character Based Database
false
Oracle Client Character Set NLS_LANG
AMERICAN_AMERICA.AL32UTF8
5. General Configuration Options
Batch RMI Port
<mandatory>
RMI Port number for JMX Business
<optional>
RMI Port number for JMX Web
<optional>
JMX Enablement System User ID
<optional>
JMX Enablement System Password
<optional>
Coherence Cluster Name
<mandatory>
Coherence Cluster Address
<mandatory>
Coherence Cluster Port
<Mandatory>
Coherence Cluster Mode
prod<Mandatory>
6. OUAF TrustStore Options
Import TrustStore Directory
<Mandatory> for Prod
Choose option (1,2,3,4,5,6 <P> Process, <X> Exit):
9. When the parameter setup is complete, proceed with the option P. The utility writes the configured parameters and their values into the configuration file.
10. Once the install or upgrade has finished, the installation log location is displayed on the screen. If the log does not list any error messages, the installation of the application component of Oracle Utilities Application Framework is complete.
You can now install Oracle Utilities Market Settlements Management as described in the following section.
Alternatively, you can follow these steps to upgrade a Oracle Utilities Application Framework version which is lower than 25.4 to version 25.4 or higher.
Note that these instructions refer to Unix platforms. For Windows, use the “.cmd” extension instead of “.sh” and provide the syntax for respective environmental variables and directories.
1. Install the prerequisite software on the server.
Java 17
Oracle FMW Infrastructure 14
Oracle Database Client 19c
2. Shut down the environment that you need to upgrade.
3. Take a full backup of the environment.
4. Run the following command:
splenviron.sh -e <ENV_NAME>
5. Run the following command:
ksh ./install.sh -u
6. Run the “configureEnv.sh -i” command and set Oracle Client Home, Web Java Home, and Web Application Server Home.
7. Run the “splenviron.sh -e <ENV_NAME>” command.
8. Run the “configureEnv.sh” and update Domain Home Location (menu block_52), ports, and server, if needed.
9. Run the “configureEnv.sh -ic” command.
10. Run the “configureEnv.sh -c” command.
11. Run the “initialSetup.sh” command.
12. Review and incorporate the content of the most recent $SPLEBASE/tools/examples/bin/setUserOverride.sh in your WebLogic 14 domain.
13. Redeploy and restart the environment and batch.
Upgrading the Oracle Utilities Meter Data Management Application Component to V25.4
This section describes how to install the application component of Oracle Utilities Market Settlements Management, including:
The Oracle Utilities Market Settlements Management installation file is delivered in jar format for both UNIX and Windows platforms.
To copy and decompress the install media, follow these steps:
2. Download the Oracle Utilities Meter Data Management V25.4 Multiplatform.zip from Oracle Software Delivery Cloud.
3. Create a temporary directory such as c:\ouaf\temp or /ouaf/temp. (Referred to below as <TEMPDIR>.)
4. Unzip Oracle Utilities Meter Data Management V25.4 Multiplatform.zip to get the file MDM_V25.4.zip from the delivered package and copy to the <TEMPDIR>. If you are using FTP to transfer this file, remember to use the BINARY option.
cd <TEMPDIR>
unzip MDM_V25.4.zip
cd App
To install Oracle Utilities Market Settlements Management application component:
1. Login to the application server host as Oracle Utilities Application Framework Administrator (default cissys).
2. Change directory.
<install_dir> is the location where the Oracle Utilities Application Framework application component is installed.
3. Initialize the environment by running the appropriate command.
UNIX
Windows
4. Run the install script.
Note: On UNIX, make sure that you have the proper execute permission on install.sh.
UNIX
ksh ./install.sh
Windows
install.cmd
5. Select menu item 8 to configure OSB.
Use the completed OSB configuration worksheet to assist you in this step. Refer to Installation and Configuration Worksheets. Select menu item 9 to configure SOA.
6. Select menu item 10 to configure the SOA Configuration Plan.
Use the completed SOA Configuration Plan worksheet to assist you in this step. Refer to Installation and Configuration Worksheets.
When the parameter setup is complete, choose option P to proceed with the installation.
Note: Rest of the menu items can be ignored if you are installing only Oracle Utilities Meter Data Management.
The Oracle Utilities Market Settlements Management Application Server installation is complete if no errors occurred during the installation process.
Creating WebLogic Domain
Create the WebLogic native domain and deploy the application. For instructions refer to the Native Installation Oracle Utilities Application Framework (Doc ID: 1544969.1) white paper on My Oracle Support.
The MDB user configured in Menu 3 during the Oracle Utilities Application Framework installation has to be created in the Oracle Utilities Application Framework application and WebLogic console, and should be part of the “cisusers” group.
Note: When starting Oracle Utilities Market Settlements Management for the first time, log into the WebLogic console and provide system access to the cisusers role. Use the following URL to access the WebLogic console application: http://<hostname>:<portname>/ console.
After the Upgrade
After you complete the upgrade installation, verify the following:
1. Verify installation logs created under decompressed installer location for any errors.
2. Confirm installation logs do not contain any errors.
3. Confirm all the configurations are correct. Refer to Installation and Configuration Worksheets for details.
4. Confirm that the database is ready.
5. Start the application server. For instructions, refer to Common Maintenance Activities.
6. To operate the application, refer to the Operating the Application section.
