Maintaining Measuring Components
You use the Measuring Component portal to maintain measuring components.
You can access the portal from Menu > Device > Measuring Components. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
This portal includes the following zones:
Measuring Component: defines the basic attributes of the measuring component
Initial Measurement Data History: lists the last 50 initial measurements for the measuring component in reverse chronological order.
Measuring Component Profile Use: lists all profile factors on which the measuring component is referenced as a factor value.
Measurements: lists final measurements for the measuring component, including any derived values for each measurement. Note: depending on the type of measuring component this zone may be the Interval, Scalar, or Subtractive Interval variant.
Device Configuration Overview: Displays an overview of the measuring component's parent device's configurations over time, including the measuring components associated with each configuration, and service points (along with the relevant install events) at which the device's configurations have been installed over time, if any exist.
Data Requests: Lists data requests for the measuring component. Applicable only for Standalone Data Request measuring components (based on the Standalone Data Request MC business object)
Measuring Component Comparison Period Details: Lists comparison periods for the measuring component (created when the current measuring component is compared to another measuring component via the Interval Proxy Day Estimation VEE rule)
