Command | Outbound Communication | Outbound Messages | Completion Event |
Device Commissioning (see Note below) | SSN - Replace Location (D7-ReplaceLocationDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Replace Location: SSN - Replace Location (Comm) OB Message (D7-ReplaceLocationOBMsg) | Device Commissioning Completion Event |
Device Decommissioning | SSN - Replace Device At Location (Decomm) (D7-ReplDeviceAtLocForDecommDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Replace Device at Location: SSN - Replace Device At Loc O/B Message: (D7-ReplaceDeviceAtLocOBMsg) | Device Decommissioning Completion Event |
Remote Connect | SSN - Connect or Disconnect (D7-ConnectDisconnectDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Connect Disconnect: SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg) | Connect Device Completion Event |
Get Status: SSN - Get Status (D7-GetStatus) | SSN - Get Job Status Outbound Message (D7-GetJobStatusOutboundMsg) | ||
Result: SSN - Connect Disconnect Results (D7-ConnectDisconnectResultDR) | SSN - GetConnectDisconnectResult OB Message (D7-GetCntDiscntResultOBMsg) | ||
Remote Disconnect | SSN - Connect or Disconnect (D7-ConnectDisconnectDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Connect Disconnect: SSN - Connect Disconnect OB Message (D7-ConnectDisconnectOBMsg) | Disconnect Device Completion Event |
On-Demand Read (Scalar) | SSN - Add Meter Read Job (Scalar) (D7-AddMeterReadJobScalarDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Add Meter Read Job Scalar: SSN - Add Meter Read Job Scalar OB Msg Type (D7-AddMeterReadJobScalarOBMsg) | Create IMD Completion Event |
Result: SSN - Meter Read Results (Scalar) (D7-MeterReadResultsScalar) | SSN - GetMeterReadResults(Scalar) By JobId (D7-GetSclrMtrRdRstByJobIdOBMsg) | ||
On-Demand Read (Interval) | SSN - Add Meter Read Job (Interval) (D7-AddMeterReadJobIntervalDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Add Meter Read Job Interval: SSN - AddMeterReadJob Interval OB Msg Type (D7-AddMeterReadJobIntervalOBMsg) | Create IMD Completion Event |
Result: SSN - Meter Read Results (Interval) (D7-MeterReadResultsInterval) | SSN - GetMeterReadResults(Interval) By JobId (D7-GetIntMtrRdRsltByJobIdOBMsg) | ||
Device Status Check | SSN - Add Ping Job (D7-AddPingJobDR) | Find Device: SSN - Find Device Outbound Message (D7-FindDeviceOutboundMsg) Add Ping Job: SSN - Add Ping Job OB Message (D7-AddPingJobOBMsg) | |
Result: SSN - Ping Results (D7-PingResultsDR) | SSN - Get Ping Results O/B Message (D7-GetPingResultsOBMsg) |
