Defining Maintenance Objects
A maintenance object defines the configuration of a given “entity” in the system. It includes the definition of the tables that together capture the physical data for the entity. In addition, the maintenance object includes options that define important information related to the maintenance object that may be accessed for logic throughout the system. Several algorithm plug-in spots are also defined on the maintenance object, allowing for business rules that govern all records for this maintenance object.
Many maintenance objects in the system support the use of business objects to further define configuration and business rules for a given record. Refer to
Maintenance Objects for more information.
Parent topic
