Maintenance Object - Maintenance Object Tree
You can navigate to the Maintenance Object Tree to see an overview of the tables and table relationships associated with the maintenance objects.
Description of Page
This page is dedicated to a
tree that shows the maintenance object's tables as well as
 business objects, if you have defined any. You can use this tree to both view high-level information about these objects and to transfer to the respective page in which an object is maintained.
Parent topic
