Adapter Development Kit CIM Command Flows
The table below lists the communication flows used with Common Information Model (CIM) commands, including:
  • Command: The specific smart meter command
  • Outbound Communication: The outbound communication business object created by the command. This sends the command request to the head end system.
  • Inbound Communication: The inbound communication created by the response from the head end system
  • Completion Event: The completion event(s) triggered by the command, if any. Completion events are used to update data in the system as a result of a smart meter command. For example, if a command changes the status of a device, the completion event is responsible for making that change.
Command
Completion Event
Device Status Check
ADK CIM Ping Direct Route (DG-CIMPingDR)
ADK CIM Ping Response Direct Route (DG-CIMPingResponseDR)
On-Demand Read (Interval) [CIM]
ADK CIM On-Demand Read Direct Route (Interval) (DG-CIMGetMtrReadIntervalDR)
ADK CIM On-Demand Read Response Direct Route (DG-CIMMtrReadResponseDR)
Create IMD Completion Event
On-Demand Read (Scalar) [CIM]
ADK CIM On-Demand Read Direct Route (Scalar) (DG-CIMGetMtrReadScalarDR)
Configuring Command Types
The following communication business objects (from the table above) all have corresponding communication types that must be configured before communications based on those business objects can be created. The table below lists the communication type business objects used with each.
Communication Business Object
Communication Type Business Object
ADK - CIM Ping DR Type (DG-CIMPingDRType)
ADK - CIM Ping Async Response DR Type (DG-CIMPingResponseDRType)
ADK - CIM On-Demand Read (Interval) DR Type
(DG-CIMGetMtrReadIntervalType)
ADK - CIM On-Demand Read (Scalar) DR Type
(DG-CIMGetMtrReadScalarType)
ADK - CIM AsyncReply MeterReads DR Type
(DG-CIMMtrReadResponseDRType)
Refer to  Communication Types for more information about communication types.
