Configuration Steps
Configuration of the Adapter Development Kit to support conversion of non-standard formats into the “native” format involves the following steps:
- Create a “parser script” that converts data from the incoming
format into Plain XML format.
See Payload Processing User Exit Interceptor Scripts for more information.
 - Create a “transformer script” that converts data from the Plain
XML format to the “native” format.
 - Create an SGG Payload Processing Configuration extendable lookup
value with a Payload Handler Class Name of
“com.splwg.d1.domain.sgg.dg.processing.PayloadHandlerViaUserExits”.
See Creating SGG Payload Processing Extendable Lookup Values for more information.
 - Specify the parser script for the “On Get Parser” Payload Processing
User Exit Type in the User Exit Interceptors section on the SGG Payload Processing Configuration extendable lookup.
 - Specify the transformer script for the “On Get Transformer” Payload
Processing User Exit Type in the User Exit Interceptors section on the SGG Payload Processing Configuration extendable lookup.
 - Create other objects and data used with payload processing, including:
- Key Rings and Pairs (See Creating Key Rings and Pairs)
 - Object Storage Locations (See Creating Object Storage Locations)
 - File Storage Extendable Lookup values (See Creating File Storage Extendable Lookup Values)
 - Head End System (See Creating Head End Systems)
 - Payload Processing Batch Controls (See Creating Payload Processing Batch Controls)
