Checking In an Object
You must check in a revision controlled object in order to create a new version of it. Checking in an object also allows others to check it out.
  1. Select a link in the Checked Out dashboard zone to go to the object that you want to check in.
  2. Select Check In in the Revision Control dashboard zone.
  3. Provide details about the version:
    • In the External References field state the bug number, enhancement number, or a reason for the revision.
    • In the Detailed Description field provide additional details regarding the revision.
    • In the Keep Checked Out box specify if you want to keep the object checked out. If you keep the object checked out then your revision is a new version that you can restore later.
    • In the Add To Bundle box specify if the object belongs to a bundle.
  4. Select OK to check in the object.
