Defining Service History Questions
You use the Service History Question portal to display and maintain Service History questions.
You can access the portal by selecting Admin, then Asset Management, then Service History Question. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Question: This zone provides information about the question.
  • Service History List: This zone displays a list of service history types that reference the question.
