Maintaining Service History
You use the Service History portal is used to display and maintain service history records.
Refer to About Service History for additional functional information.
You can access the portal from Menu > Asset Management > Service History. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Service History: This zone displays the basic attributes of the service history record.
