Maintaining Manufacturers
You use the Manufacturer portal is used to display and maintain manufacturers.
Refer to About Manufacturers for additional functional information.
You can access the portal from Menu, then Asset Management, then Manufacturer. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Manufacturer: This zone displays the basic attributes of the manufacturer.
- Manufacturer Models: This zone displays a list of models associated with the manufacture. To add or edit models available for the manufacturer, click Edit in the zone title bar.
- Manufacturer Specifications: This zone displays a list of specifications associated with the manufacturer. Use the Specification portal to add or edit the specifications associated with the manufacturer.
