Configuring Usage Subscription Types
This portal is used to display and maintain a Usage Subscription Type.
You can access the portal by selecting Admin, then Usage, then Usage Subscription Type.
  • Usage Subscription Type List: displays all of the Usage Subscription Types so you can choose the one you want to display in more detail
  • Usage Subscription Type: shows the specific configuration for the selected Usage Subscription Type
The Usage Subscription Type defines a number of lists for "valid" objects that can be used in conjunction with the overall usage calculation process:
  • Valid Usage Recipients
  • Valid Service Point Types
  • Valid Usage Calculation Groups
  • Valid Dynamic Option Types
