Configuring Settlement Subscription Types
You can access the portal by selecting Admin, then Settlement, then Settlement Subscription Type.
  • Settlement Subscription Type List: This zone lists all usage subscription type records. Broadcast a record to display the details of the selected record.
  • Settlement Subscription Type: This zone displays details for the selected usage subscription type.
The settlement subscription type defines a number of lists for valid objects that can be used in conjunction with the overall usage calculation process:
  • Valid Settlement Calculation Groups
  • Valid Recipients
Settlement subscription types also define the outbound communication type used when sending the results of settlement transactions based on settlement subscriptions of this type.
