Maintaining Attribute Data Snapshots
You use the Attribute Data Snapshot portal to view and maintain attribute data snapshots.
You can access the portal by selecting Main, then Customer Information, then Attribute Data Snapshot. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Attribute Data Snapshot: This zone displays the attribute data snapshot.
