Maintaining Settlement Item Quantities
You use the Settlement Item Quantity portal to view and maintain settlement item quantities.
You can access the portal by selecting Main, then Settlement, then Settlement Item Quantity. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
  • Settlement Item Quantity: This zone displays the basic attributes of the settlement item quantity
