Message Option
The Message Option page defines various system settings used by the system when processing external messages.
To define options for your environment, open Admin > Integration > Message Option.
Description of Page
The following options are supported.
Option Description Option Name
Default Email Sender This is the default Message Sender used for sending e-mails when no explicit Message Sender is specified. defaultEmailSender
Default User The default user is used by the system to access your product when no other user is explicitly specified. defaultUser
Email Attachment File Location This is the default location of e-mail attachment files. If not specified, the e-mail service provided with the product assumes a full path is provided with each attachment file. emailAttachmentFileLocation
Email XSL File Location This is the default location of e-mail XSL files. If not specified, the e-mail service provided with the product assumes a full path is provided to an XSL file as part of an e-mail request. emailXSLFileLocation
Messages Language The default language to use for the messages. language
Outbound Message Schema Location Enter the full path of the virtual directory where valid W3C schemas are stored if your implementation wants to validate outbound message schemas. For example: http:/localhost/cisxai/schemas. xaiOuboundSchemaLoc
Schema Validation Flag Enter Y to turn on schema validation for outbound messages. Enter N to turn this off. xaiSchemaValidationCheck
Note that the following options are no longer applicable.
Option
To Do Type for Inbound JMS Message Errors
To Do Type for Outbound Message Errors
XSD Compliance
