Defining Custom Data Delimiters and Enclosing Characters
The default configurations are delivered with the base product.
Your entire legacy data or a specific table, or the data extract mechanism may require use of a different data delimiter and/or enclosing characters. To enable alternative delimiters, perform the following steps:
Define new data delimiter string, enclosing string, CLOB delimiter string and/or CLOB Line Separator using the corresponding Extendable Lookups
Configure Conversion Task Type using newly created delimiters
Amend Conversion Master Configuration, setting default (for all tables or maintenance objects) or override (for specific table or maintenance Object) instructions.
Regenerate Conversion Artifacts
Now you can create data extract according to the newly generated specifications.
