Maintaining Asset Replication
You use the Asset Replication portal is used to display and maintain asset replication activities.
Refer to About Asset Replication for additional functional information.
You can access the portal from Menu > Asset Management > Asset Replication. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
- Asset Replication: This zone displays the basic attributes of the asset replication activity.
- Completion Event: This zone displays a list of completion events related to the asset replication activity.
