Creating CIM Payload Processing Extendable Lookup Values
Payload processing of CIM usage and events requires configuration of values for the SGG Payload Processing Configuration extendable lookup. This section outlines the specific configuration for usage and event payload processing extendable lookups for CIM usage and events. See Creating SGG Payload Processing Extendable Lookup Values for more information about this extendable lookup including parameters not listed in this section.
Usage
Extendable lookup values for CIM usage payload processing should include the following parameters:
  • Payload Handler Class Name: com.splwg.d1.domain.sgg.dg.processing.PayloadHandlerViaUserExits
  • Payload Processing Result Type: Initial Measurements
  • IMD Seeder BO (Interval): IMD Seeder (D1-IMDSeeder) (Applicable only If processing interval usage)
  • IMD Seeder BO (Scalar): IMD Seeder (D1-IMDSeeder) (Applicable only If processing scalar usage)
  • Dynamic Parameters: As appropriate for your implementation
  • User Exit Interceptors:
Payload Processing User Exit Type
Groovy Library Script
Groovy Library Method
On Get Parser
DG_​CimUPrXML (SGG ADK Generic CIM XML Parser)
getParser
On Get Transformer
DG_​CimUTrXML (SGG ADK Generic CIM XML Transformer)
get Transformer
Device Events
Extendable lookup values for CIM event payload processing should include the following parameters:
  • Payload Processing Result Type: Device Events
  • Device Event Seeder BO: Device Event Seeder (D1-DeviceEventSeeder)
On Get Parser
DG_​CimEvntPr (CIM Events Parser using XMLReader)
getParser
On Get Transformer
DG_​CimEvntTr (CIM Events Transformer)
get Transformer
