Jump to main content
Oracle Utilities Meter Solution Cloud Service
Search
Home
Oracle Utilities Meter Solution Cloud Service User Guides
Administrative User Guide
Meter Solution Administrative User Guide
Smart Grid Gateway Adapters
Smart Grid Gateway Adapter Middleware Implementations
Creating a Custom Adapter for Smart Grid Gateway
Oracle Service Bus Processing
Oracle Utilities Smart Grid Gateway Adapters
OSB Configuration
Business User Guide
Framework Administrative User Guide
Meter Solution Products Functional Overview
Additional Resources
Best Practices
System-Wide Options
Defining General Options
Defining Asset Options
Defining Location Options
Defining Device Options
Defining Device Installation Options
Defining Measurement Options
Defining Validation, Editing, and Estimation (VEE) Options
Defining Usage Options
Defining Time of Use Mapping Options
Defining Communications Options
Configuring Smart Grid Gateway Adapters
Using Smart Grid Gateway Middleware Test Harnesses
Adapter Development Kit Overview
Adapter Development Kit Processing
OSB Overview
Adapter Components
Processing Life Cycle
Java Project
OSB Configuration
OSB Project Summary
OSB Project Implementation Details
Setting Up the Adapter Environment
Additional Information
Business Processing Execution Language Processing
Configuring an Adapter Development Kit Head-End System
Configuring Adapter Development Kit Extendable Lookups
Using the Adapter Development Kit Test Harness
The Adapter Development Kit Native Format
Adapter Development Kit Native Format Example
Adapter Development Kit Native Format Schema
Smart Grid Gateway Adapter Native Implementations
Defining Service Order Management Options
Defining Settlement Options
Additional Independent Modules
Integrations
Oracle Utilities Cloud Service Foundation
OSB Configuration
This section outlines the OSB projects provided with the Adapter Development Kit.
OSB Project Summary
