Report Definition - Main
Navigate to this page using
.Description of page
Enter an easily recognizable Report Code and Description for each report. Use the External Reference ID to define the identifier for this report in your external reporting tool.
Define an application service to enable users to request submission of this report online or to view report history for this report. Once you define an application service for each report, use Secured Objects and Application Services to define which users may access this report.
If you have more than one parameter defined for your report and you wish to perform cross-validation for more than one parameter, provide an appropriate Validation Algorithm.
Enter a Long Description to more fully describe the functionality of this report. This information is displayed to the user when attempting to submit the report online or when viewing history for this report.
For BI Publisher, if you want to use one of the sample reports provided by the system, but with a different layout, indicate the layout to use for the report in the Customer Specific Font/ Layout field and BI Publisher uses this information instead. The name for base report layout is <report code>_Base. For example, a base layout for CM_TODO is named CM_TODO_Base.
