Mass Asset Disposition Update
You use the Mass Asset Disposition Update portal is used to update the disposition of a group of assets.
More specifically, Mass Asset Disposition is used for moving many assets of the same type from one location to another location. In a mass disposition task, the target is always a single asset location. For example, if a pallet of meters has been received in the receiving asset location, mass disposition can be used to move this batch of assets to a storage asset location or an out of service location.
Refer to About Assets for additional functional information.
To use the Mass Asset Disposition Update portal:
- Select Menu > Asset Management > Mass Asset Disposition Update.
You are brought to a query portal with options for searching assets
- Enter search criteria appropriate to the asset you wish to update and click Search.
- From the list of search results, select the assets you wish to update and click Change Disposition.The Mass Asset Disposition Update screen opens.
- Enter the date and time at which the update should take effect in the Effective Date/Time field.
- Select the new disposition for the assets from the Asset Disposition drop-down list.
- Select the new location for the assets from the Location drop-down list or field.
- Select or enter other data as appropriate (based on the new disposition). For instance, if you select “Rejected” you must also select a reason from the Reason drop-down list.
